Torque Arm Bushing Gap - JeepForum.com
post #1 of 7 Old 10-26-2010, 06:59 PM Thread Starter
sherwoodiv
I tore a transmission mount wheeling the other weekend. I was getting a ton of clunking on starting in 1st gear. With the usual MeanMax writeup and a little CubeWiz write up plus some searching I got the parts swapped out.
At first I wasn't getting any clunking anymore without trying REALLY hard. I noticed a new clunk up front and turns on one of my motor mounts seems pretty shot in the rubber dept. I've got new ones on the way. The clunking got worse today. I wanted to make sure my torque arm as the right amount of play in it. It seems excess, but does match the CJ pic threads I saw in the search.
What do you guys think?
These are the threads I used:
http://www.jeepforum.com/forum/f12/h...ement-1075968/
http://www.jeepforum.com/forum/f12/t...cement-903109/
1991 YJ 4.0 MT
2001 TJ 4.0 MT
sherwoodiv is offline
post #2 of 7 Old 10-26-2010, 07:05 PM
4.7stroker
That dosen't look right to me. BTW I found that with the Brown Dog motor mounts I do not need the torque arm at all. I just have a tranny mount and the Brown Dog motor mounts and everything is happy.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 7 Old 10-26-2010, 07:09 PM Thread Starter
sherwoodiv
I am missing the push nut I've seen on some diagrams, but other than that all the parts are there. The push nut was not there. I figured it only made life easier by keeping the washer in place before replacing skid plate. Fortunately the nut worked and my rusty skid plate had enough room to pass the nut through so I could remove it and put the lowest washer and nut back on.
I ordered the Brown Dog motor mounts so hopefully this will just go away, but I agree it doesn't look right.
1991 YJ 4.0 MT
2001 TJ 4.0 MT
post #4 of 7 Old 10-29-2010, 09:50 PM Thread Starter
sherwoodiv
any suggestions?
anyone think it looks ok?
My engine mounts masked the problem, but I still think this doesn't line up
1991 YJ 4.0 MT
2001 TJ 4.0 MT
post #5 of 7 Old 10-30-2010, 09:34 AM
chicalibro3
Mine looks the same. I don't know if that's
a good or bad thing.
chicalibro3 is offline
post #6 of 7 Old 10-30-2010, 05:58 PM
4.7stroker
With the Brown Dog motormounts I don't run the torque arm, I have not had an issue in 3 years.
Dwayne
[url]
[url]
post #7 of 7 Old 10-30-2010, 08:05 PM
dodger889
I order poly urethane engine mounts from summit racing no problems with a clunking without the torque control arm.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
torque bushing set up? acat YJ Wrangler Technical Forum 2 09-12-2010 09:11 PM
Torque Shaft Bushing suntzur TJ Wrangler Technical Forum 2 02-09-2009 04:50 PM
Torque Arm Bushing And Bolt Devildog985 YJ Wrangler Technical Forum 5 10-15-2007 05:10 PM
Torque arm bushing bolt? krugon YJ Wrangler Technical Forum 4 08-30-2006 10:34 PM
Torque Shaft Bushing replacement DonDonn TJ Wrangler Technical Forum 2 05-27-2004 08:07 PM
