Torque Arm? - JeepForum.com
post #1 of 10 Old 09-21-2005, 05:53 PM Thread Starter
JPH
JPH's Avatar
Torque Arm?
Question on a 95 2.5L Ax5:
Sandwiched between the trans and the crossmember/factory skid plate, right where the trans mount is, there is an arm parallel to the x-member with the exhaust mount on one side (ahead of the convertor), and a set of bushings on the other. These bushings have a stud through the center that mount directly to the x-member.
Is this the torque arm?
I thought a torque arm is a bar that links the trans to the rear diff, and the only diagram showing this in the FSM is for a 4.0 engine. The bushings on mine are rotted out and the stud through the center just spins. I am hoping this solves a knock whenever I change directions. These things are pretty cheap, but I only want to buy them once!
'95 YJ 4.0L/AX-15
JPH is offline
post #2 of 10 Old 09-21-2005, 06:03 PM
ncjeepinyj
ncjeepinyj's Avatar
I had to replace mine (95 with a 2.5 also) because the nuts on mine are would just spin and wouldnt tighten. I thought that was my problem, and it partly was, but i also had a bad motor mount that caused similar symptoms that you described. Might be worth checking that then too.
ncjeepinyj is offline
post #3 of 10 Old 09-22-2005, 07:54 AM Thread Starter
JPH
JPH's Avatar
Yeah I was thinking about taking a look at the motor mounts as well. I'll change the trans mount while I'm under there working on the torque arm. That is the torque arm I'm talking about, right?
'95 YJ 4.0L/AX-15
JPH is offline
post #4 of 10 Old 09-22-2005, 04:10 PM
ncjeepinyj
ncjeepinyj's Avatar
I believe that is it. I have heard of it called a transmission stabilizer syud as well. But i am sure we are talking about the same thing.
post #5 of 10 Old 09-22-2005, 04:30 PM Thread Starter
JPH
JPH's Avatar
Good. Quadratec has them for 5 bucks a pair. If it doesn't fix the clunk, at least it isn't a wasted effort. I'm not big on having loose mounts!
If anyone else is looking for these things, here they are:
http://www.quadratec.com/cgi-bin/sgsh0101.exe
'95 YJ 4.0L/AX-15
JPH is offline
post #6 of 10 Old 09-22-2005, 05:50 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
No one is questioning the 'why is it there' issue. Why does the 4 cyl have a torque arm and the 6 cyl not. That is actually the first one I have seen on any engine actually. I can not imagine 6" arm heavily rubber mounted can do much to stop anything. We think nothing (apparently) of removing sway bars and track bars, yet this thing has to be there? I would 't bother with it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #7 of 10 Old 09-22-2005, 06:06 PM Thread Starter
JPH
JPH's Avatar
Actually, according to the FSM, the 6 cylinder has it, and a 4 banger doesn't. But on mine, which is a 2.5, there it is! I'm hoping that the popping noise I hear when I let the clutch out after going from reverse to 1st gear, is this stud being pushed and pulled through the bushings due to the torque from the engine.
U-joints are good, tranny shifts good, transfer shifts and works good. Everything has had an oil change, and I didn't drain out any chunks. The only mount I can see that looks damaged is this one. I've been driving it like this for the last 10 months since I bought it, and except for the noise, it doesn't have any other symptoms.
Any ideas, JeeperDon?
'95 YJ 4.0L/AX-15
JPH is offline
post #8 of 10 Old 09-22-2005, 06:34 PM
wolf3902
My 2.5L AX-5 has it too. it's loose also, but doesn't clunk yet.
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
post #9 of 10 Old 09-22-2005, 07:50 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
i seem to remember reading somewhere that they're supposed to be a little loose and that the bushing cushion the arm when it stops to keep it from clunking. at least that's what the archives are telling me i don't have one so can't tell you for sure.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #10 of 10 Old 09-22-2005, 08:16 PM Thread Starter
JPH
JPH's Avatar
I don't honestly know if it is going to fix it or not, but it is worth the 5 bucks to satisfy my curiosity. If it works, I'll let post it.
'95 YJ 4.0L/AX-15
JPH is offline
Lug Nut Torque Hilldweller JK Wrangler Technical Forum 13 08-30-2014 10:50 AM
Does socket extension on torque wrench change torque? itasor TJ Wrangler Technical Forum 44 09-25-2009 02:20 PM
No Torque? JustInJeeps YJ Wrangler Technical Forum 5 09-05-2009 08:30 AM
Torque converter bolt torque misprint! planedog YJ Wrangler Technical Forum 7 03-16-2009 12:48 PM
Lug Nut Torque Jcpierc21 TJ Wrangler Technical Forum 3 02-21-2005 05:24 AM
