Tore out stock aircleaner in 88, put back in but have "extra" tube (pic) - JeepForum.com
post #1 of 12 Old 07-12-2009, 12:26 PM Thread Starter
kgillette
I tore out my stock intake in the hopes of removing and replacing.. however since moneys tight, I instead just cleaned up the rust. changed the oil and plugs and flushed the cooling system.
My big issues is that I didn't label everything and am now looking at an unhooked tube that I'm not sure where it is suppose to connect too.
On top of that she wont start anymore... starts to go but wont turn-over...
88 Wrangler - Build Thread: http://www.jeepforum.com/forum/f12/88-yj-fix-turned-build-956202/#post8758947
kgillette is offline
post #2 of 12 Old 07-12-2009, 12:48 PM
Jim Piszar
Jim Piszar's Avatar
Whoa! That picture is way too close. Is one end of your loose line connected to something? Maybe someone else can make heads or tails of what we are looking at.
Try this and trace every line.
http://home.sprynet.com/~dale02/vacuhose.htm
Jim Piszar is offline
post #3 of 12 Old 07-12-2009, 12:51 PM
UnFocused
That hose runs from the decel valve to a tee in the rear hose from your air cleaner (AC) to the pulse valve. There are two hoses from the AC to separate pulse valves - the tee is in the rear one under the AC.
UnFocused is offline
post #4 of 12 Old 07-12-2009, 01:16 PM Thread Starter
kgillette
that is what I thought, but the tube isnt long enough to go to either of the hose ports on the bottom of the AC... where is the other pulse valve in comparison to the one in the pic, because I have to spots for the tubes on the bottom of the AC
would these two unhooked pulse lines be a reason why the engine wont turn over?
post #5 of 12 Old 07-12-2009, 01:28 PM
UnFocused
The valve in the pic is the decel valve, not a pulse valve. The twin pulse valves and associated check valves are located on the passenger side of the engine near the firewall. There are two hoses about 1 inch OD which connect to the AC and run back and down to the pulse valves, one may have a white stripe on the top of it. The tee is in the hose without the white stripe, so the hose in the pic needs to cross over the valve cover and connect to the tee.
And no, this isn't the reason you're not starting and running - that's something else. Storms here now and inet connections are unstable - sorry.
post #6 of 12 Old 07-12-2009, 01:34 PM Thread Starter
kgillette
Im not sure how my setup is in comparison to a standard setup The P/O did a bunch of things to it and left alot of the now unused wires/tubes in place, ex switching out the vacuum 4x4 system with a cable activated 4x4.
Here are two more pics of what everything is looking like now:
post #7 of 12 Old 07-12-2009, 02:21 PM
UnFocused
Can't tell from the pics. Need a couple of the passenger side behind the AC towards the firewall, sort of quartering over the distributor if that makes sense.
post #8 of 12 Old 07-12-2009, 04:35 PM Thread Starter
kgillette
it does, my wireless is flaky as all today... just got it back up and running (sorta)
thanks for the info, I'm going to check it out and then take a couple pics if I cant get it all back together.
post #9 of 12 Old 07-12-2009, 05:43 PM Thread Starter
kgillette
here are some more pics:
post #10 of 12 Old 07-13-2009, 06:12 AM
UnFocused
Looks like the entire pulse system is missing. No hoses from the AC, no pulse valves and no check valves, at least I couldn't see them in the pics. The check valves below the pulse valves connect to metal pipes; one runs aft to your catalytic converter, the other runs behind the engine to the header pipe just below the exhaust manifold. That would be a quick check to see if the PO stripped the whole system.
post #11 of 12 Old 07-13-2009, 09:10 AM Thread Starter
kgillette
Thats what I was thinking, however never seeing this engine fully in-tack I wasn't sure. I'll be check that tonight. So if the pulse system is infact all gone, the hose going off the decal valve would need to be connected into the AC anyways, or can it just be left unhooked?
post #12 of 12 Old 07-15-2009, 07:58 AM Thread Starter
kgillette
looks like it has been gutted.
Buy 2.5" dia. cat back or pay extra $$ and stick with 2.25" LandoCommando TJ Wrangler Technical Forum 15 11-18-2009 07:05 AM
"Will my tires fit without extra spacers"????/ freefalldusty TJ Wrangler Technical Forum 10 05-26-2009 09:40 AM
Want a 4" or 5" lift, but need to re-gear and is an extra 3,000 1BADYJ88 YJ Wrangler Technical Forum 12 01-13-2009 06:47 PM
Tube Fenders with stock rubi's or other 32"s JeepinMass JK Wrangler Technical Forum 15 02-26-2008 04:03 AM
Pic Request: TJ, 2"BB, 1" BL, 1"MML, 33x10.5", Stock Rims 04JeepTJ TJ Wrangler Technical Forum 4 07-30-2004 07:12 AM
