Tops and weather - JeepForum.com
post #1 of 5 Old 03-26-2001, 10:12 PM Thread Starter
Nine5YJ
Tops and weather
Hey-
Since warmer weather is apporaching here in New England, I was thinking of putting on a new soft top. The one I have is a raggy and missing various pieces of hardware. Instead of buying a new top for $400+, I was starting to look at just buying a bikini top, tonneau cover, and acrylic windscreen(pg 26 JC whitney JEEP)or windjammer and save around $275. MY QUESTION IS THIS: does much rain or wind penetrate through to the interior? ( In the pictures in the mag it looks like there are some gaps) If anyone has a setup like that, any input would be greatly appreciated. Thank you very much!
Tom
95 YJ
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #2 of 5 Old 03-27-2001, 03:58 AM
jeffy
jeffy's Avatar
From what I've seen, you'll get leaking from the gap between the rollbar and door. Both form on top and from the back.
The only halfcab top that seals out the weather completely that I know of is from California Tops. www.californiatops.com. I've got a bikini top and duster cover that I use when it's sunny.
*** www.4BangerJP.com ***
jeffy is offline
post #3 of 5 Old 03-27-2001, 09:54 AM
Cody_91YJ
Yea, your gonna get some leakage.
But it would be better then being wide open.
Soft Top prices are a little cheaper now, so it may be worth the investment, espationally
when winter rolls around
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #4 of 5 Old 03-28-2001, 12:47 PM
jmsjeep
All I have is the bikini setup with windbreaker ((pg. 12 and 19 in JC Cat)which will make a better seal with tonneau) and tonneau/duster or my hard top.
Same situation you are proposing. Its not bad when you have all the pieces on and your driving in the rain (except when you get a cross wind, like at a stop light). But if you do not garage it or have a cover to throw over it(pg.11 JC catalog) your seats and floor will get soaked when and rains and thier is any wind. Gaps around doors and in the back at roll bars are big. But this setup looks much cooler than a soft top.
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #5 of 5 Old 09-23-2001, 11:03 AM
Double Down
Yeah man, just to let you know it's good if you dont want to get REALLY wet. But i will garuntee the first time you sit in the driver seat of the jeep after it rains you'll be pissed. If you leave it over night and its not garaged, or there is a tremendous storm and you are out and about you will get wet, the floors will be soaked, and after it has stopped, you will have massive and i mean massive puddle on the roof and the back cover. it may sound bad but you get used to it, and i enjoy having mine.
Double Down is offline
Do Hard tops & Soft Tops Leak? Thisisaustin Wrangler General Discussion 15 04-29-2009 10:21 PM
Soft tops, door surrounds, and safari tops Rigger007 TJ Wrangler Technical Forum 11 07-27-2008 10:54 AM
are bikini tops weather proof? losfreddy TJ Wrangler Technical Forum 15 03-30-2006 08:15 PM
Are Bestop Soft-tops and Replace-a-tops better thank factory? Rapajez TJ Wrangler Technical Forum 4 05-09-2004 03:52 PM
Skinz Soft Tops ? Tops that rest on roll bar ? tire_smoke YJ Wrangler Technical Forum 2 06-30-2002 02:45 AM
