post #1 of Old 05-03-2007, 11:40 AM Thread Starter
1969cj5
Top patent numbers - please help
Tried the search function with no luck. I am looking at buying a top that is advertised as a SuperTop which I need to run with my YJ full doors. There is not a model number on the tag just patent numbers. Can someone look at the patent numbers on their YJ supertop and match with these?
4600235 / 4757854 / 0322,055
Thanks
Chris
1969cj5 is offline
post #2 of Old 05-03-2007, 12:10 PM
Michael_94YJ
where would those numbers be located on the top?
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
http://i178.photobucket.com/albums/w...y/Image075.jpg
Michael_94YJ is offline
post #3 of Old 05-03-2007, 12:12 PM Thread Starter
1969cj5
sorry, I believe they ate on the tag, the one that says besttop.
Thanks for asking
C
1969cj5 is offline
post #4 of Old 05-03-2007, 12:19 PM
GrimJeeper91
GrimJeeper91's Avatar
Does it have the rounded door opening (the corner by your ears)? This is very rounded on the Supertop and really square on factory and replacement tops.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #5 of Old 05-03-2007, 12:20 PM Thread Starter
1969cj5
Thanks for asking
C
are on the tag
1969cj5 is offline
post #6 of Old 05-03-2007, 12:22 PM Thread Starter
1969cj5
Cant see the door opening in the pics and the guy doesn't sound sure. It would have to be rounded and come pretty far up to meet the hard door though.
1969cj5 is offline
post #7 of Old 05-03-2007, 12:28 PM
Michael_94YJ
i've got the bestop supertop and my jeep is in the parking lot and i'm at work. Any idea where to look and i'll run out there for ya. I don't recall ever seeing a tag on my top. you need pictures?
1994 YJ 4.0L 5 spd.
post #8 of Old 05-04-2007, 11:39 AM Thread Starter
1969cj5
There should be a tag on the back of the top, around the rear windows, side or back
Thanks
1969cj5 is offline
post #9 of Old 05-04-2007, 12:03 PM
Michael_94YJ
Thanks
Ok gotcha. Mine says:
Patent#: 4600235 4757854 AND/OR 0322,065
on that last number, its hard to read because it's sewed or embroided on but that "065" may be a "055" but my best guess was "065". The first two sets of numbers should be 100% accurate though. Hope this helps
btw, i have a 94' YJ full steel doors with the grey bestop supertop. and tinted window inserts but those were seperate.
1994 YJ 4.0L 5 spd.
post #10 of Old 05-04-2007, 12:05 PM
Michael_94YJ
ha! i just re-read your original post. I guess that last set of numbers IS "055". Cool, they match!
1994 YJ 4.0L 5 spd.
post #11 of Old 05-07-2007, 05:14 PM Thread Starter
1969cj5
thanks
Thanks for the help, what comes around goes around!
Thanks again
1969cj5 is offline
post #12 of Old 08-06-2012, 11:03 AM
Jarosegolf
Window Header for this Soft Top - HELP?
Guys,
I hope you are still out there and can help me. Attached are a couple pics of a Best top with the same patent numbers. I am looking for the Window Header for this unit and I am lost. Nothing like I have seen... Please help!
Jarosegolf is offline
post #13 of Old 03-10-2016, 02:13 PM
edl88
Can anyone tell me what year, make and model this Bestop fits? I actually have a top and I am trying to sell it, but I don't know what it fits. The numbers match exactly in your original question. Please help.
edl88 is offline
post #14 of Old 03-11-2016, 08:19 AM
Que89YJ
It fits all years. It only works with the soft top uppers.
https://www.youtube.com/watch?v=JwWoWCa_JWw
Que89YJ is offline
post #15 of Old 03-11-2016, 07:42 PM
edl88
Thank you very much.
edl88 is offline
Opinions on my alignment numbers needed please...are these numbers okay or way off? Stacydmcc JK Wrangler Technical Forum 3 10-08-2009 04:20 PM
what do these numbers mean? jeepin1995 YJ Wrangler Technical Forum 5 08-07-2006 12:20 PM
Does anyone have a ref for Vin numbers aeguy010 TJ Wrangler Technical Forum 2 08-03-2006 11:47 AM
Numbers? MCanavan TJ Wrangler Technical Forum 4 04-12-2005 04:43 PM
VIN Numbers robnrob2 TJ Wrangler Technical Forum 3 08-10-2004 10:56 AM
You may not post new threads
You may not post replies
