Top End Rebuild-run into piston ring problems! - JeepForum.com
post #1 of 3 Old 06-21-2010, 06:12 PM Thread Starter
grimjeeperyj14
Im am rebuilding a 1990 4.2 and need advice on what to do. I honed the carbon and such out of the cylinders and plan on putting standard size rings back in. My problem is all the cylinders measure the correct bore diameter(maybe .001 over) but the #1 cylinder measures .003 over. due to a broken ring ,can I still use the standard ring or will this screw it up? I really dont want to have it bored over at this time, can I make it work?
-I plan on using a rebuilt 4.0 head on the 4.2 block. I have read it increases compression if that matters.
Driving my Jeep is uncomfortable, loud and drafty.... and I love every minute of it
grimjeeperyj14 is offline
post #2 of 3 Old 06-22-2010, 10:35 AM Thread Starter
grimjeeperyj14
Any suggestions, Im sure someone has fixed something like this before?
post #3 of 3 Old 06-22-2010, 10:55 AM
pasinbuy
I do not think that .003 will make a differance. Take a piece of regular notebook paper and measure it. Notebook paper is .003 inches thick.
.030 is a differant matter.
pasinbuy is offline
Why can't I do a piston & ring replacement with the engine still attached? rain-gler YJ Wrangler Technical Forum 17 04-02-2009 07:04 PM
Having some Auto trans problems tf999 rebuild jeepinjc YJ Wrangler Technical Forum 10 01-20-2009 01:30 PM
No!!! need LoD help. D ring problems. :( bman9089 TJ Wrangler Technical Forum 15 12-16-2008 09:24 PM
231 problems and rebuild Q's TyJeep TJ Wrangler Technical Forum 6 06-19-2008 01:59 PM
Snap Ring/Retaining Ring Pliers SYE Install mking7 TJ Wrangler Technical Forum 7 09-29-2004 10:55 AM
