Too much amperage? - JeepForum.com
post #1 of 14 Old 08-23-2011, 05:45 AM Thread Starter
ikircher
Too much amperage?
hello once again everyone! First, The title should read "too much voltage" lol... I recently had to clean up my battery terminals in order to get my jeep (95 wrangler, 2.5 liter, 5speed). Normally when I start and drive the jeep the battery volts are right at 14 on the gauge. Today the gauge was reading a little higher. The needle was at the last line before the red zone. When does too many volts cause a problem? I had my battery, alternator, and starter all tested and they came back fine. Could this be because maybe there is some more crud on the cables/terminals? or maybe a short somewhere? I figured if there was a short from the alternator my battery would be dead overnight but I don't really know. Any help would be much appreciated!! Thanks in advance!
ikircher is offline
post #2 of 14 Old 08-23-2011, 06:07 AM
tdewit
Rather then believing the gauge, I would actually measure the voltage at the terminals.
Interesting question. Items like your radio normally have a bit of a working range, from 9 to 17VDC, light bulbs have a wider span of acceptance to voltage fluctuation.
Look at the basic ohms law equation, V=IR. Crud = R (high resistance) Short = R (low resistance). If you have a short, you'll blow a fuse.
The only thing I would look at is the alternator, seems to be overcharging.
tdewit is offline
post #3 of 14 Old 08-23-2011, 06:18 AM
oldtime_ironman
Mine was reading high until I did the gauge-cleaning trick:
http://www.jeepforum.com/forum/f12/r...ter-how-991307
Now the gauge matches the DMM right at 13.8 volts. This is ideal.
Too many volts starts to cause problems when you get up over 14 volts. With 14.2 volts, the battery will overcharge and boil, most likely ruining the battery. As the voltage goes higher, more and more things will start to fry out. A shorted-out voltage regulator will "full-field" the alternator, which can often put out 19 or 20 volts. At that point things just go up in smoke and you would be looking at replacing most of the wiring.
oldtime_ironman is offline
post #4 of 14 Old 08-23-2011, 07:11 AM
Que89YJ
Important! Stop driving it immeadiately! In an over charging condition(Full Field) you are dumping way more power into the battery then it can take and there is a high risk of the battery cracking and exploding! This is not anything to play with!
Verify the guage with a meter and post back. If it is overcharging then park it until you can fix the issue.
Que89YJ is offline
post #5 of 14 Old 08-23-2011, 09:40 AM Thread Starter
ikircher
ok thanks guys. I will check the volts when I get a break from work...Probably in like 4 hours. Excuse me if this sounds like common sense but in order to get an accurate reading, I need to have the jeep running to test the volts correct?
ikircher is offline
post #6 of 14 Old 08-23-2011, 09:43 AM
Que89YJ
Yes, you should test both.
Que89YJ is offline
post #7 of 14 Old 08-23-2011, 02:31 PM Thread Starter
ikircher
I just tested the battery with the jeep off and it read 13.8. With the jeep on the battery read 14.0. If I revved the engine it read 14.1 for a split second then back down to 14.0... I am thinking it must be my gauge in the jeep. It read below 14 when idling and then it was up around the line right before the redline when I would accelerate... Does everything sound right?
ikircher is offline
post #8 of 14 Old 08-23-2011, 02:37 PM
Que89YJ
Yes you are fine. There is an adjustment for the voltage gauge. I will post it tomorrow
Que89YJ is offline
post #9 of 14 Old 08-23-2011, 02:43 PM Thread Starter
ikircher
Ok awesome.. Thank you so much Que
ikircher is offline
post #10 of 14 Old 08-23-2011, 02:45 PM
tdewit
tdewit is offline
post #11 of 14 Old 08-23-2011, 11:24 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Test the "battery resting voltage" - engine off, accessories off, read across the battery terminals. Nominal is 12.6VDC, acceptable is 12.0-12.8VDC (anything over 12.8VDC tends to be a "surface charge," and isn't useful for automotive purposes.)
Test voltage again, putting the positive probe on the B+ stud on the back of the alternator. Should be 0.02VDC less than at the battery terminals - or higher. But, it shouldn't be any higher than battery resting voltage (the alternator B+ post is always connected directly to B+ via a fuse or fusible link.) A large drop between the battery + post and the alternator B+ post is indicative of a faulty connexion somewhere.
The running system voltage (basic test: engine running, accessories off) at the battery terminals should be sufficient - if the prior two voltage tests came out OK. System charging voltage should be 0.5VDC higher than resting voltage - at least. Nominal is 13.4VDC, with acceptable being 13.0-14.0VDC. (oldtime_ironman is entirely correct - above 14.0VDC, you start overcharging the battery. Above 14.2VDC, you're boiling the battery! The higher the voltage is, the faster the battery will be wrecked (boiling the top 1/2" or so of plates clear will pretty well wreck the battery totally...)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #12 of 14 Old 08-24-2011, 05:50 AM Thread Starter
ikircher
Ok I will try that too when I get home tonight around 7pm eastern time. I drove the jeep today and everything went smoothly. The gauge on the jeep still reads a little higher abover the 14 mark. After I test what you said then that will guarantee that the gauge is screwed up if everything comes back ok. Thank yoU!!
ikircher is offline
post #13 of 14 Old 08-24-2011, 06:27 AM
Que89YJ
The alternator output is PWM for the OBDI and will vary depending on load. I agree with everything you said except the 14 volts. Most of the modern cars run at 14.5 Vdc from the alternator. Boiling off the battery is a result of full fielding the alternator. The output from the alternator becomes unregulated and will put out 16-18Vdc at as much current as it can crank out. The exposed plates are nothing compared to the Hydrogen sulfied you produce. It is nasty smelling like rotten eggs and very explosive.
Read the voltage at the battery and tune the guage to the battery. As long as you are around 14.5 Vdc you are fine.
Que89YJ is offline
post #14 of 14 Old 08-24-2011, 07:45 AM Thread Starter
ikircher
again thank you guys so much. This is easily the most helpful forum I have ever been part of and joined. Thank you!!
ikircher is offline
97 TJ Alternator Replacement Amperage rocketag98 TJ Wrangler Technical Forum 3 07-15-2010 03:32 PM
stock amperage draw rescueTJ TJ Wrangler Technical Forum 0 06-03-2008 09:43 PM
Arb lockers and amperage. OBA and amperage. jeepster93 YJ Wrangler Technical Forum 1 02-29-2008 03:23 PM
More amperage? PlanetDac YJ Wrangler Technical Forum 7 05-22-2005 06:04 PM
Switch Amperage?? skotsour YJ Wrangler Technical Forum 3 03-12-2004 12:05 PM
