too much all at once? - Page 2 - JeepForum.com
post #16 of 22 Old 01-10-2013, 08:31 PM
YJ-Nation
Also if you're not running an SYE with your current lift that can make for a bad ride if you're getting any vibration especially in your stick shift you should put one in.
YJ-Nation is offline
post #17 of 22 Old 01-10-2013, 09:04 PM Thread Starter
Steve707
Originally Posted by NHfireYJ View Post
You already have a HP30... its fine...
Im planning on getting two axles geared and set up for soa so i can have everything set up to go in at once. Id like to have as little down time as i can since i have roommates and cant just park it in the garage for extended periods of time.
Steve707 is offline
post #18 of 22 Old 04-17-2013, 04:08 PM Thread Starter
Steve707
I've got the axle set under the jeep with the weight of the jeep on the springs. I pointed the pinion at the yoke and rolled it down two degrees, and I should be ready to tack it up. But I feel like I'm forgetting something... Right now the angle is 24 degrees, that should change though once I have the tires on, and the front gets lifted.
I know its not the best picture, but I can take others if needed.
Steve707 is offline
post #19 of 22 Old 04-17-2013, 04:12 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I'm in CA and interested in your BDS 3.5 spring Kit. When you are ready to sell PM me. Thanks!
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #20 of 22 Old 04-17-2013, 04:15 PM Thread Starter
Steve707
I'm not so sure you want it.
Steve707 is offline
post #21 of 22 Old 04-17-2013, 04:19 PM
Luuca
Luuca's Avatar
Originally Posted by BDS Website
BDS Suspension's No-Fine-Print Warranty
This unique warranty proves our commitment to the quality and reliability of every product we make.The No Fine Print warranty does not include shock and stabilizer cylinders.
No Fine Print Warranty logo | BDS SuspensionNo Fine Print Warranty
If you are the original purchaser of any BDS product and it breaks, we will give you a new part. Period.
I guess the only question is, Are you the original purchaser?
YJOTM never
Luuca is offline
post #22 of 22 Old 04-17-2013, 04:21 PM Thread Starter
Steve707
Unfortunately no, I bought them off craigslist last year. But if you're willing to try, you can have the springs.
Steve707 is offline
