Too many puddles..rough starting - JeepForum.com
post #1 of 8 Old 06-10-2013, 09:24 PM Thread Starter
Corvo838
Hey guys, so in a recent rainstorm I couldnt resist but to turn towards massive puddles. I was hitting puddles like a foot deep or so. Then I came to a stop and when giving her gas to get going it was putting out and then getting sudden acceleration until I shifted and then similar putting then acceleration. I got to a gas station and it wouldnt turn over when trying to. Sat there 20 minutes just thinking then tried again and she turned over barely. Kind of was just going blub blub blub for 10 seconds then fired up. Now when I turn it over it has a rough start (as it barely starts). I also get a good wiff of gas and if I hit the gas when shes idleing it hesitates before reving up. Any ideas folks?
Corvo838 is offline
post #2 of 8 Old 06-11-2013, 01:11 AM
Michaelgoesrawr
I'd say you probably got water in the distributor cap. Take it off and shoot some *i think Wd-40* in there and see what happens.
Michaelgoesrawr is offline
post #3 of 8 Old 06-11-2013, 05:10 AM
jsawduste
2006 YJ Wrangler
Replace the waterlogged airfilter
jsawduste is offline
post #4 of 8 Old 06-11-2013, 01:08 PM Thread Starter
Corvo838
I replaced distributor cap, rotor and wires and still am having the same problem. It has been turning over now but it is one ugly start and if I hit the gas hard it will hesitate and sputter. After it happened I checked if the air filter was wet and it was dry as a bone.
Corvo838 is offline
post #5 of 8 Old 06-11-2013, 02:19 PM
Rproject
1987 YJ Wrangler
Pull the plugs and clean them as well as the air filter as recommended above. Don't forget to clean the plug wire boots at both ends.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 8 Old 06-11-2013, 03:19 PM
Jstout724
Might be a long shot, but ya might of got some water in your gas (maybe disconnected rollover valve or leaking tank seal) ... or perhaps in your charcoal canister. Maybe check that guy out, easy to pull out. Otherwise i'd run some seafoam or heet through it just in case, a cheap fix if so.
Jstout724 is offline
post #7 of 8 Old 06-11-2013, 11:02 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A liberal amount of dielectric grease will keep water out.
Luck Favours The Prepared
Anticanman is offline
post #8 of 8 Old 06-14-2013, 02:28 PM Thread Starter
Corvo838
Found out the problem when checking for spark. Coil pack was not putting out nearly enough. Took it off and popped in a new one. Old coil pack was split right down the bottom. Problem fixed and runs great. Thanks people
Corvo838 is offline
