Todays Fabrication Projects (Highline, Fenders, etc) - JeepForum.com
post #1 of 21 Old 07-03-2009, 05:02 PM Thread Starter
Blue70
OK... had a day working on the Jeep and did a few things...
First on the front....
Started with stock cut fenders.
Then cut them off
Then marked off 3" of the hood
And cut that off too
Made some new fenders, and decided to make a sexy little vent... just to try it
and painted
Blue70 is offline
post #2 of 21 Old 07-03-2009, 05:03 PM Thread Starter
Blue70
Now to the back
Marked where I decided to cut
and cut it out
but it went up into the wheel house area
(Knew this before I started)
So I built a little "arm rest"
Blue70 is offline
post #3 of 21 Old 07-03-2009, 05:03 PM Thread Starter
Blue70
Few before and afters
Blue70 is offline
post #4 of 21 Old 07-03-2009, 05:05 PM
JaikYJ
That turned out pretty good. Nice work
I am still waitin on some steel before I flat fendr mine. I like the vents on the front. Turned out nice.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #5 of 21 Old 07-03-2009, 05:30 PM Thread Starter
Blue70
Thanks, I'm thinking about cutting the front of the raised black area in the middle of the hood,
and dropping it down to vent the hood like I did the fenders, kind of like one wide 03 Cobra style
Blue70 is offline
post #6 of 21 Old 07-05-2009, 04:40 PM
Dewster196
Blu those came out really nice I like it. Jeeps looking good, how is the rear tire carrier holding up?
Dewster196 is offline
post #7 of 21 Old 07-05-2009, 08:16 PM Thread Starter
Blue70
So far so good.. only open it about once a week, but I could not ask for better
Blue70 is offline
post #8 of 21 Old 07-07-2009, 11:22 AM
zekeman023
Highline turned out awesome! Couple questions: it looks like you kept the inner fender, did you move it up to sit flush with the hood or did you just fill the gap with the new tube fender top? Also what worked best to cut the hood and fenders? Your other hood modifying idea sounds cool too, but wouldn't it pool with water which then would pour into your engine bay, or am i misunderstanding?
zekeman023 is offline
post #9 of 21 Old 07-07-2009, 11:29 AM
YJake
Nice work!
What kind of paint did you use for the OD job? I want to do something similar.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #10 of 21 Old 07-07-2009, 11:32 AM
sebastian22
That is one BAD *** Jeep! Great work.
95 Black YJ
sebastian22 is offline
post #11 of 21 Old 07-07-2009, 12:10 PM
Edstu234
Love the look of the new fenders.
Edstu234 is offline
post #12 of 21 Old 07-07-2009, 01:01 PM Thread Starter
Blue70
No I did not move the inner fenders up, I filled the gap above them.
I used a plasma cutter to cut everything, but on my old CJ I used a cutoff wheel and that worked fine, just took a bit longer to cut, then the edges were cleaned up with a flap wheel if needed..
Yes the scoop would funnel water and dump it on the engine, but who cares, its not going to hurt anything,
Blue70 is offline
post #13 of 21 Old 07-07-2009, 01:45 PM
fyrdriver
1983 CJ7
That really looks good, its a much more "finished" look. Good job.
Firefighters Jeep Club
fyrdriver is offline
post #14 of 21 Old 07-07-2009, 03:38 PM Thread Starter
Blue70
Originally Posted by MosinMe View Post
Nice work!
Ultra Flat Krylon Camo paint in a rattle can for the whole Jeep
Blue70 is offline
post #15 of 21 Old 07-19-2012, 11:11 PM
rambo3489
Looks good. Looks REAL good. I will be using this as a template when I work on mine later on down the road.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
Homebrew Highline Fenders Hapytruck01 TJ Wrangler Technical Forum 85 04-21-2016 08:47 PM
AEV highline fenders and hood ActionJackson00 TJ Wrangler Technical Forum 49 04-09-2009 06:50 PM
Highline Fenders a little different 1BadTJ TJ Wrangler Technical Forum 52 08-10-2008 04:37 PM
highline hood/fenders daj012jeep YJ Wrangler Technical Forum 4 06-02-2008 03:01 PM
Highline fenders / Brute WCoon YJ Wrangler Technical Forum 3 02-19-2008 10:21 AM
