Is the TJ/XJ Axle Shaft a different diameter? - JeepForum.com
post #1 of 30 Old 12-26-2011, 09:41 PM Thread Starter
idskot
Recent my actuator went out, and I was looking for different ways to fixing it, and I of course inquired about a new actuator, and Posi-Lok, and was then informed I could forego the whole CAD system and swap in a TJ / XJ front axle shaft (passenger side), so I went and picked one up today.
But something struck me: is this shaft thicker than my stock YJ shafts?
Also, if anyone else has done this, where did you seal the axle?
I plan on doing the swap tomorrow, so information would be awesome!
idskot is offline
post #2 of 30 Old 12-26-2011, 09:52 PM
kloppk
Yup - the TJ/XJ shaft will fit.
You will need to install a NAPA 11800 seal in the passengers side of the diff in the axle tube.
Will require pulling the carrier out to install the seal.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 30 Old 12-26-2011, 09:57 PM
toolegit86
i think Tjs are 30 spline. U can swap them in but need a locker or spiders with matching splines. Xj work. Look for the 270x ujoint axles 96 and up there the strongest oem.
Adrenaline Motorsports
1989 yj. Hp60f/60rear disk. Teralow 4.6stroker. All the bolt ons..etc..
1983 camaro build in progress. 1996 dodge tow rig.
2005 gto corvette spec 6.0 6 speed
toolegit86 is offline
post #4 of 30 Old 12-26-2011, 09:57 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The TJ/XJ 1 piece passenger side shafts are actually smaller in diameter.
I sealed my old HPD30 at the carrier. Lots of folks use Napa PN CR11800.
This is a TJ on top, YJ bottom & the seal package:
Joe Dillard is offline
post #5 of 30 Old 12-26-2011, 09:59 PM
Joe Dillard
post #6 of 30 Old 12-26-2011, 10:01 PM
toolegit86
Before i broke my cad axle i was lookin to do this swap. And i was told tj shafts are 30 spline. And could do the swap if i put a locker or spiders n... I put a hp60 and trashed the 30 lol
post #7 of 30 Old 12-26-2011, 10:05 PM
Joe Dillard
Somebody gave you bogus info.
Check the TJ stock sticky spec post #8 here: http://www.jeepforum.com/forum/f9/st...1/#post4118396
post #8 of 30 Old 12-26-2011, 10:33 PM Thread Starter
idskot
Would it be considered bad practice to seal it at the CAD entry rather than at the carrier?
The reasoning behind this is because I've never took a carrier out, and I'd rather keep it simple and put more gear fluid in there.
idskot is offline
post #9 of 30 Old 12-26-2011, 10:47 PM Thread Starter
idskot
Also: There's a bit of rust toward the end of the shaft, should I sand it down a tip?
And can I also reuse the ujoint I have already?
Here's a picture of the shaft (I pulled it out of an XJ)
(Excuse the dirty oil pan. I left it out side and the lawn guy was blowing stop everywhere.)
idskot is offline
post #10 of 30 Old 12-26-2011, 11:14 PM
timatoe
timatoe's Avatar
The seal goes at the end down there by the splines, where it's all nice and shiny so no need for sanding anything. If you Google "TJ shaft in YJ" you'll get tons of info.
timatoe is online now
post #11 of 30 Old 12-27-2011, 12:34 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Luck Favours The Prepared
Anticanman is offline
post #12 of 30 Old 12-27-2011, 12:36 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
And no, the ujoints are different from yj to tj/xj.
post #13 of 30 Old 12-27-2011, 01:56 AM Thread Starter
idskot
So should I just use that whole assembly? Just pop it in and reconnect the rotor / brakes?
& will I have a balance issue?
idskot is offline
post #14 of 30 Old 12-27-2011, 05:36 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
They are 27 spline.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #15 of 30 Old 12-27-2011, 08:28 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
No balance issue unless you're talking about your driveshaft, it may. Eed to be balanced. The whole setup is fine to just install but take the opportunity to replace the ujoints in the xj shafts with 760 series hardware. You'll thank yourself later even if it's because you have new joints.
Dana 44 axle tube diameter bombman0513 TJ Wrangler Technical Forum 7 06-05-2015 10:43 AM
Use a 91 AX15 in my 97 - input shaft diameter PoopFaceKillah TJ Wrangler Technical Forum 2 09-06-2010 05:57 PM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 12:42 PM
d35 axle tube diameter FF151DJG TJ Wrangler Technical Forum 1 01-13-2008 06:06 PM
Internal diameter of front xj shaft tube... mississippi_xj YJ Wrangler Technical Forum 7 11-17-2006 09:04 PM
