TJ style downpipe? - JeepForum.com
post #1 of 15 Old 02-01-2013, 01:08 PM Thread Starter
YJ4LIFE
TJ style downpipe?
Is there any reason not to run the exhaust in front of the oil pan like on the TJ in a YJ? Will that heat up the starter too much? Is the TJ starter in a different place? No right?
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #2 of 15 Old 02-01-2013, 01:23 PM
jbolty
jbolty's Avatar
you mean like this? It is not all that close to the starter but I attached a piece of tin to the joint clamp to act as a heat shield anyway.
not nearly as close as it looks like
jbolty is offline
post #3 of 15 Old 02-01-2013, 02:03 PM
OKwranglerYJ
I'm going to try and have that done in mine when I get my exhaust redone.
OKwranglerYJ is offline
post #4 of 15 Old 02-01-2013, 02:43 PM
NHfireLJ
NHfireLJ's Avatar
$58 bucks at Autozone
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #5 of 15 Old 02-01-2013, 03:34 PM
kirksjeep
I bought one from a local guy doing a 350 swap. Much better clearance. Only negative is that the passenger side floorboard gets a little warmer.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
post #6 of 15 Old 02-01-2013, 05:45 PM
Day215
I picked mine up from ebay, Walker part # 53458, under $60. I had to put a few pieces in to get it connected to my existing stuff, but everything's available from autozone. No cons, great clearance, do it!
Day215 is offline
post #7 of 15 Old 02-01-2013, 05:58 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Mine.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #8 of 15 Old 02-01-2013, 06:09 PM
flcracker
Question.... does the 2.5 exhaust route around the front like that also or is this a 4.0 thing only??
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #9 of 15 Old 02-02-2013, 06:13 AM
TheRealOldjeep
The 2.5 TJ exhaust also routes around the front of the pan. I've got a TJ downpipe on my 2.5
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #10 of 15 Old 02-02-2013, 10:24 AM
flcracker
I guess I can go with that when its time for exhaust, thanks....
post #11 of 15 Old 02-02-2013, 10:27 AM
jeepster93
jeepster93's Avatar
Mine:
jeepster93 is offline
post #12 of 15 Old 04-16-2014, 05:13 AM
The_Goob
Hell on Wheels
The_Goob's Avatar
Sorry for the necro, but if you run it this was can you remove the oil pan without unbolting the pipe? In the Midwest you don't unbolt exhaust you usually end up cutting it off :0
-April '14- YJoTM- June '15]
The_Goob is offline
post #13 of 15 Old 04-16-2014, 05:37 AM
Louie4
Since the sump in the pain has the oil pick-up tube and screen, I would say you need the pipe off.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #14 of 15 Old 04-16-2014, 08:26 AM
rocketboy
rocketboy's Avatar
So, if I have a 4.2, can I use a TJ down pipe? I think the manifolds are different. Can I use a TJ 4.0 manifold on a 4.2?
rocketboy is offline
post #15 of 15 Old 04-16-2014, 08:40 AM
AmmitOsiris
AmmitOsiris's Avatar
If you put a 4.0 head on your 4.2 yes you can
YES.
AmmitOsiris is offline
