TJ Soundbar in a YJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > TJ Soundbar in a YJ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-17-2014, 08:50 AM   #1
brianhorne8
Anyone know if a soundbar for a TJ will fit in a YJ? Dimensions, width-wise, don't seem to be much different on the exterior, but I haven't measured the roll bar to see.
brianhorne8 is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 09:07 AM   #2
TCXJWagoneer
Minor detail
I would like to know this as well. I need some tunes in the Jeep
95 YJ 4 banger
SOA
31x10.50
SYE
Super 35 kit with Auburn E-locker
Rear swing-out bumper
Champion 8K winch
TCXJWagoneer is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 09:57 AM   #3
rogerv
rogerv's Avatar
I just asked my son, via text msg, about his because he dropped a TJ sound bar in his 93. According to him the fit was no problem and no modifications were not needed.
If it's not broke- modify it, so it won't break
rogerv is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 10:16 AM   #4
medic-11
The rear bars on a TJ are parallel (upper horizontal parts), while on a YJ family bar they spread apart as they go towards the rear. I know YJ bars are closer together where they attach to the main hoop. Post back with some pics so others can learn from your experience.
medic-11 is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 10:28 AM   #5
fishadventure
The TJ soundbar will work in the rearmost position. Others are correct- it won't mount in a forward position. Stock speakers are blah- sounds ok with rear channels of head unit equalized to cut out mid- to high-ranges leaving the dash speakers to project these frequencies (if your head unit can do this; pioneer calls this FIE: front image enhancement.) Keeps the overheads from drowning out conversation etc. I am thinking of swapping the full-range speakers out for a three way and clipping the tweeter feeds. Buttttttt I digress; TJ bar is fine. You may want a connector to plug it in though. Somebody shared a link to them on eBay in the midst of a similar thread.
Just to avoid any confusion;
Originally Posted by roadyrob
most people mount them on the windshield bar, in front of the main hoop.
That's what I meant- didn't think they could be done any other way w/ std. single hoop bar
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 11:21 AM   #6
roadyrob
1987 YJ Wrangler
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is online now   Reply With Quote Quick reply to this message
Unread 10-17-2014, 11:28 AM   #7
jbolty
jbolty's Avatar
This. I forget if it was too wide or narrow but in any case it was not a good fit behind the hoop.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 12:06 PM   #8
TCXJWagoneer
Minor detail
Pics?
95 YJ 4 banger
SOA
31x10.50
SYE
Champion 8K winch
Unread 10-17-2014, 12:18 PM   #9
rogerv
rogerv's Avatar
This is my sons 93
Hope this helps
Unread 10-17-2014, 01:01 PM   #10
brianhorne8
Originally Posted by rogerv View Post
Attachment 1659322
This is my sons 93
Attachment 1659338
Hope this helps
Perfect! I'm in a 91 and don't have the family bars. Doesn't seem like that'll make a difference; correct me if I'm wrong.
Unread Yesterday, 09:42 PM   #11
fishadventure
FYI the TJ soundbar I have came with factory installed "full range" speakers. I paid $30 for it. They are 5-1/4" and didn't sound great but weren't too awful, either. But my Pioneer was a little much for them sometimes.
An improvement - a remarkable improvement - for only $30 can be had, however. While not as nice as perhaps new Polks or my old Altec Lansing back in the 80s, in my heep the Scosch 5.25 3-ways improved the base and really cut down on the midrange peakiness. Not only that they don't sound over-driven. I recommend this lo-buck upgrade.
Again, this isn't a high end approach but it's pretty darn good sound improvement for very little cash.
