TJ soft top on YJ - JeepForum.com
post #1 of 4 Old 05-20-2010, 07:00 AM Thread Starter
57plymouth
TJ soft top on YJ
There is a black TJ top for sale locally that I would like to use instead of the gray one on my YJ. Will it fit? It says it has all the hardware. I currently have a Supertop and I do not have any factory YJ hardware.
Thoughts?
Virtus Junxit Mors Non Separabit
57plymouth is offline
post #2 of 4 Old 05-20-2010, 08:44 AM
WakeDoctor
No, the tubs are different sizes and it requires modification to the TJ hardware to even fit the YJ
WakeDoctor is offline
post #3 of 4 Old 05-20-2010, 01:16 PM Thread Starter
57plymouth
Okay then. Not such a good deal.
post #4 of 4 Old 05-20-2010, 02:37 PM
J33Pyj
I used a soft top from a 99 Tj on my 90 YJ for about 2weeks. it fit really loose the back was not bad but the front was since the front attaches different.
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
JK Unlimited Standard Soft Top v Sun Rider Soft Top...Pics please SJP-07JKx JK Wrangler Technical Forum 10 07-10-2015 04:43 PM
Bestop Tinted Soft Top Windows and Factory Soft Top firehawk_1989 JK Wrangler Technical Forum 2 05-21-2010 10:10 AM
Bestop makes 2 piece soft doors which match with Factory soft top? AROSETO TJ Wrangler Technical Forum 9 02-23-2010 11:41 AM
Need soft top - Whats the scoop on Viking soft tops? Q-01 TJ Wrangler Technical Forum 3 01-11-2008 07:36 AM
Soft top issue problem solver, must read if you have a YJ soft top marvin51796 YJ Wrangler Technical Forum 9 03-04-2005 12:50 PM
