Tj shafts into YJ D30 - Page 3 - JeepForum.com
post #31 of 48 Old 06-11-2013, 10:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Hope ya get it working. Keep us updated.
Anticanman is offline
post #32 of 48 Old 06-11-2013, 11:35 PM Thread Starter
Dake
Dake's Avatar
I found this in the TJ section. The one on the right is from auto zone like I have. I will not activate the light.
Waiting on my Rough Country lift to sag!
Dake is offline
post #33 of 48 Old 06-12-2013, 02:00 PM
kjg26
kjg26's Avatar
What did you use to finally seat the seals properly?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #34 of 48 Old 06-12-2013, 02:22 PM
Destr0
Just curious as to why do the switch at all? I did a TJ shaft (with full circle clips) about a month ago and no problems with my 4X4 light on the dash just using the old Vacuum housing - I suppose if the vacuum motor ever fails I will look into doing this upgrade...
And I managed to not kill my Napa seal on the first try, only because I bought two. :-)
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #35 of 48 Old 06-12-2013, 02:46 PM
kjg26
kjg26's Avatar
Any hints on how to seat these seals.
kjg26 is offline
post #36 of 48 Old 06-12-2013, 02:53 PM
dillonjm
2013 WK
I used a large socket that was just a tad smaller than the OD of the seal and tapped it in with a hammer. I don't remember the exact size socket.
Haven't damaged a seal using this method and I've done a few.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #37 of 48 Old 06-12-2013, 03:17 PM
Destr0
This is exactly how I did mine (I also replaced the drivers side seal while I had it all apart). Just use little taps and it will start to go in crooked- tap on the opposite side to drive it in as straight as you can.
1981 CJ7 SBC 350
Destr0 is offline
post #38 of 48 Old 06-12-2013, 05:29 PM
PA_YJ19
This explains my problem. I had one working originally then a tree broke the connection on top. Ordered a dorman one, now it doesn't work and I can't feel it hit the ball like I could with the other one I had. I don't remember where I bought the original tho, I ordered the dorman one off eBay cuz it was cheap. Looks like I need to go grab one that's a diff brand.
PA_YJ19 is offline
post #39 of 48 Old 06-12-2013, 05:55 PM
PA_YJ19
Just ordered one made by crown, hopefully it works better than the Dorman one.
PA_YJ19 is offline
post #40 of 48 Old 06-12-2013, 06:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Do you have a part number from crown? If so, would you mind adding it to the write up?
Thanks!
http://www.jeepforum.com/forum/f12/t...80/?highlight=
post #41 of 48 Old 06-12-2013, 06:46 PM
PA_YJ19
Sure do, part number is J8134473. Ill check back after I receive it and try it out. Pretty sure it's the same one I orinally had tho.
PA_YJ19 is offline
post #42 of 48 Old 06-16-2013, 01:32 PM Thread Starter
Dake
Dake's Avatar
Did this switch work?
Dake is offline
post #43 of 48 Old 06-16-2013, 02:37 PM
PA_YJ19
Still waiting on it to get here. Ill let u no in the next few days.
PA_YJ19 is offline
post #44 of 48 Old 06-16-2013, 08:35 PM Thread Starter
Dake
Dake's Avatar
Cool I'm waiting to order one
Dake is offline
post #45 of 48 Old 06-17-2013, 05:53 AM
PA_YJ19
Alright ill let ya no, I'm taking the jeep for inspection on Tuesday so I might not get around to it until Wednesday.
PA_YJ19 is offline
