Tj shafts into YJ D30 - JeepForum.com
post #1 of 48 Old 06-08-2013, 11:27 AM Thread Starter
Dake
Dake's Avatar
Ok I got all my parts to do this today. Now I have read put the seal at the cad or at the differential on the passenger side? I don't see a spot for the seal on the passenger side of the Differential
Waiting on my Rough Country lift to sag!
Dake is offline
post #2 of 48 Old 06-08-2013, 11:40 AM
dillonjm
2013 WK
There isn't one there stock.
The 11800 seal has an OD that allows a tight seat into the tube.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 48 Old 06-08-2013, 11:48 AM Thread Starter
Dake
Dake's Avatar
Inside the Differential? on the passenger side not at the CAD?
Dake is offline
post #4 of 48 Old 06-08-2013, 11:50 AM
dillonjm
2013 WK
Yes.
Napa 11800
dillonjm is offline
post #5 of 48 Old 06-08-2013, 11:53 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes inside the differential. Hope you got two seals, one always gets boogered up
Luck Favours The Prepared
Anticanman is offline
post #6 of 48 Old 06-08-2013, 12:09 PM
RustedWrangler
x2 napa 1800 keep all your shims etc together when you remove the carrier, and put the caps back on the same side they came off of and in the same orientation.
www.RCPFA.com
RustedWrangler is offline
post #7 of 48 Old 06-08-2013, 01:42 PM Thread Starter
Dake
Dake's Avatar
Got the axles out now I'm going to pull the carrier . I have one seal hope dont it get damaged .
Sent from AutoGuide.com Free App
Dake is offline
post #8 of 48 Old 06-08-2013, 02:23 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Got the axles out now I'm going to pull the career . I have one seal hope it get damaged .
English?
post #9 of 48 Old 06-08-2013, 03:17 PM Thread Starter
Dake
Dake's Avatar
Smart phone in the sun with spellchecker
Dake is offline
post #10 of 48 Old 06-08-2013, 04:39 PM Thread Starter
Dake
Dake's Avatar
It happen ordered two more from napa now its going to be Monday before I can finish
Dake is offline
post #11 of 48 Old 06-08-2013, 05:25 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I was just giving you a rough time.
Your jeep is just giving you a rough time.
post #12 of 48 Old 06-08-2013, 09:13 PM Thread Starter
Dake
Dake's Avatar
I installed the TC switch and it don't work. I don't think it drops in far enough? The light comes on with the wires touching.
Dake is offline
post #13 of 48 Old 06-08-2013, 09:54 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Does the light come on with the switch out of the TC? Try removing the switch and plugging it into the harness as if it were mounted. Touch the body of the switch to a known ground and try depressing the plunger. If it lites up you know it's the plate not depressing the switch. I bet it's the connector on top of the switch not making contact.
YJOTM JULY 2014
DirtKar is offline
post #14 of 48 Old 06-08-2013, 10:07 PM Thread Starter
Dake
Dake's Avatar
Yea I'm going to test it Monday. I'm not sure that plug fits to the switch vary well. I sent half my day running around trying to find a new seal I boogered up.
Dake is offline
post #15 of 48 Old 06-08-2013, 10:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Does it need to be grounded, Larry? Its just a continuation of the hot wire going to the light which should be grounded behind the dash.
Dake: did you have to cut the shaft for the SYE at all?
