-   -   Tj shafts into YJ D30 (http://www.jeepforum.com/forum/f12/tj-shafts-into-yj-d30-1533805/)
Dake 06-08-2013 10:27 AM
Ok I got all my parts to do this today. Now I have read put the seal at the cad or at the differential on the passenger side? I don't see a spot for the seal on the passenger side of the Differential:confused:
dillonjm 06-08-2013 10:40 AM
There isn't one there stock.
The 11800 seal has an OD that allows a tight seat into the tube.
Dake 06-08-2013 10:48 AM
Inside the Differential? on the passenger side not at the CAD?
dillonjm 06-08-2013 10:50 AM
Yes.
Napa 11800
Anticanman 06-08-2013 10:53 AM
Yes inside the differential. Hope you got two seals, one always gets boogered up
RustedWrangler 06-08-2013 11:09 AM
x2 napa 1800 keep all your shims etc together when you remove the carrier, and put the caps back on the same side they came off of and in the same orientation.
Dake 06-08-2013 12:42 PM
1 Attachment(s)
Got the axles out now I'm going to pull the carrier . I have one seal hope dont it get damaged .
Sent from AutoGuide.com Free App
Anticanman 06-08-2013 01:23 PM
Originally Posted by Dake (Post 15535594)
Got the axles out now I'm going to pull the career . I have one seal hope it get damaged .
English?
Dake 06-08-2013 02:17 PM
Smart phone in the sun with spellchecker
Dake 06-08-2013 03:39 PM
It happen ordered two more from napa now its going to be Monday before I can finish :(
Anticanman 06-08-2013 04:25 PM
I was just giving you a rough time.
Your jeep is just giving you a rough time.
Dake 06-08-2013 08:13 PM
I installed the TC switch and it don't work. I don't think it drops in far enough? The light comes on with the wires touching.
DirtKar 06-08-2013 08:54 PM
Does the light come on with the switch out of the TC? Try removing the switch and plugging it into the harness as if it were mounted. Touch the body of the switch to a known ground and try depressing the plunger. If it lites up you know it's the plate not depressing the switch. I bet it's the connector on top of the switch not making contact.
Dake 06-08-2013 09:07 PM
Yea I'm going to test it Monday. I'm not sure that plug fits to the switch vary well. I sent half my day running around trying to find a new seal I boogered up. :o
Anticanman 06-08-2013 09:18 PM
Does it need to be grounded, Larry? Its just a continuation of the hot wire going to the light which should be grounded behind the dash.
Dake: did you have to cut the shaft for the SYE at all?
The time now is 12:08 AM.
