TJ roll bar in YJ? - JeepForum.com
post #1 of 9 Old 06-09-2010, 12:21 PM Thread Starter
skey
TJ roll bar in YJ?
I am sure this has been addressed here in the past, what all is involved in mounting TJ family bar in a 1989 yj? Can it be done safely? Also can I get 31x10.5x15 on stock suspension? Thanks for help in advance. Sorry for goofy questions, new jeep guy.
skey is offline
post #2 of 9 Old 06-09-2010, 01:14 PM
Jims-87YJ
1987 YJ Wrangler
I am contemplating the same swap, everything I have read says that it will there may be one bolt hole that does not line up on each side on the floor but you can either enlarge or drill a new hole to fix. My biggest issues I think is getting the old one out.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #3 of 9 Old 06-09-2010, 01:24 PM
jbolty
jbolty's Avatar
YJ sport to YJ family is a direct swap. Not so sure about the TJ to YJ swap though, the rear fender wells are shaped completely different.
jbolty is offline
post #4 of 9 Old 06-09-2010, 01:31 PM
jeep16
what is better about the tj bar vs the yj family bar?
jeep16 is offline
post #5 of 9 Old 06-09-2010, 01:40 PM
BlackRhino
BlackRhino's Avatar
The TJ bar will need new holes drilled in your tub for most of the mounting points. Don't know if the TJ bar is any better than the YJ family bar.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #6 of 9 Old 06-09-2010, 08:33 PM Thread Starter
skey
Not sure TJ is better than YJ, but I have had some difficulty finding YJ family. A TJ came up for good price and the guy said it would fit my YJ. I just wanted a better opinion than the guy trying to sell it.
skey is offline
post #7 of 9 Old 06-09-2010, 10:06 PM
BlackRhino
BlackRhino's Avatar
It'll work if you're willing to drill new holes in the tub and windshield frame.
post #8 of 9 Old 06-10-2010, 12:46 AM
JeepMan1975
With the TJ rollbar, installing a TJ soft top becomes easier. And yes the rollbar will fit with some drilling.
Sitting in your Jeep does NOT count as a mod!
JeepMan1975 is offline
post #9 of 9 Old 06-10-2010, 12:57 AM
Dhofstet
1973 KK Liberty
Check this out for the TJ roll bar swap.
http://www.jeepforum.com/forum/f12/t...-pics-1046359/
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
Roll Cage in JK. Good Enough in a Bad Roll? fastRob JK Wrangler Technical Forum 61 05-28-2012 07:52 PM
Can a Bikini Top designed for a Family Roll Bar on a Sport Roll Bar? Elsahara YJ Wrangler Technical Forum 21 03-23-2010 04:54 PM
In Dash Roll Cage or Sport Roll Cage derdawa TJ Wrangler Technical Forum 4 05-11-2009 01:08 PM
Do I Have To Take The Roll Bar Apart ? Yelladog1 TJ Wrangler Technical Forum 4 03-08-2009 09:09 AM
Roll Bar Padding v. No Roll Bar Paddin UTmike TJ Wrangler Technical Forum 32 06-05-2006 10:07 PM
