Tj roll bar pads on YJ? - JeepForum.com
post #1 of 4 Old 09-13-2011, 04:29 PM Thread Starter
branjmb
Ive always liked how TJ rollbar pads are way thicker and more padded than my stock and Besttop pads--- anyone think they would fit on a YJ? And if so would they look good?
1992 Jeep Wrangler YJ
2.5 L, 33x12.5 Cooper Discover STT, Homebrew Intake, RE 4" Lift, ProComp ES9000 Shocks.
branjmb is offline
post #2 of 4 Old 09-13-2011, 06:50 PM
clarkjdg
clarkjdg's Avatar
Here is a TJ, and a YJ up side by side look at where the "back bars" are mounted on the main overhead bar, your way off sorry they wont work unless you are going to do some "major" work on the pads. The YJs are offset from the sides and the TJs are on the sides.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #3 of 4 Old 09-13-2011, 06:56 PM
Spuznick242
Search CL for a cheap used set. You might be able to use some pieces of it (like how the spreader bars sections are seprate), even if the colors off you can always dye it or paint it with the duplicolor fabric paint, its a few bucks and can and if you really like the thicker pads more it'll be a cheap, easy mod to do.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #4 of 4 Old 09-13-2011, 10:55 PM
deathtrap
I have tj rear bar pads on my 93, thay are a little shorter on top but still look good. I have the pads for the main hoop and spreder bars but havent installed them. I need to remove some stuff to know for sure but it looks like it should fit.
deathtrap is offline
