TJ RD44 under a YJ w/CS? - JeepForum.com
post #1 of 4 Old 08-01-2002, 01:02 PM Thread Starter
UPnOVER
UPnOVER's Avatar
TJ RD44 under a YJ with coil suspension.
Has anyone done this? Are there any problems that you could share with me and any tricks that could help.
I don't see a problem with it but could use some info on it.
Thank for the info.
UPnOVER is offline
post #2 of 4 Old 08-01-2002, 01:51 PM
Bob J
Bob J's Avatar
1984
if you keep stock height there shouldn't be any problem.
You might have to make some custom cross-members and brackets though.
If you just want a D44, I would cut and weld new mounts on the axle and keep the leaf spring rather then welding new mounts on the frame.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #3 of 4 Old 08-01-2002, 02:34 PM Thread Starter
UPnOVER
UPnOVER's Avatar
I am doing a spring over up front with the 3" lifted springs I have on now. I was thinking that I could find a TJ RD44 and put the 8" coil in the rear. I like the way that set up works. I have only seen it in pic and it looks like it kicks a$$. A lot of people tell me to do a spring over all around but I dare to be a little different. I also need to learn how to do the repairs so if it brakes I can fix it. I am trying to have a Built not bought rig because I do Not have good luck with mechanics.
UPnOVER is offline
post #4 of 4 Old 08-01-2002, 04:46 PM
Bob J
Bob J's Avatar
1984
if you want to be different, do coil over up front, and 1/4 eliptical in the rear
with that much lift, the longer pinion of the D44 will come into play, but I assume you already thought about/have an SYE
you might want to get HD brackets for the axle then, you will also need a trackbar relocation bracket for the axle.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
