TJ Fuel Filler on a YJ Question.. - JeepForum.com
post #1 of 29 Old 05-18-2013, 01:53 PM Thread Starter
Robob69
I want to do the MOD from a TJ fuel Filler on my YJ..
My question is this:
If I have the entire Fuel filler and hoses from the TJ do I still need to place the stainless pipe in line?
Robob69 is offline
post #2 of 29 Old 05-18-2013, 06:40 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I do not think the TJ hoses fit the YJ gas tank.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 29 Old 05-19-2013, 08:12 PM
Lemoore-on
This^ The TJ hoses dont fit the YJ tank.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #4 of 29 Old 05-19-2013, 08:30 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I did the TJ fuel filler mod on my YJ some time back. I bought the SS metal pipes I needed from onlinemetals.
I do not know if we have a JF vendor that can supply you with the same pipe needed to extend the YJ hoses.
post #5 of 29 Old 05-20-2013, 07:08 AM Thread Starter
Robob69
Okidoki..... Well if y'all can give me a little insight as to the pipe needed I will sure find it..
I am tired of fueling and jacking with the LP and fuel spillage....
Thank you
Robob69 is offline
post #6 of 29 Old 05-20-2013, 08:04 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Thank you
Here is how it gets done. I bought my pipe from onlinemetalsdotcom.
Dimensions are approximate you will need a TJ fuel filler bezel.
I DID NOT draw this diagram, and I can't credit who did so,.... because I am old and forgetful!
post #7 of 29 Old 05-20-2013, 08:19 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Two pictures of an installation; Not too sure if it is mine or not. Damn this getting old crap sucks
Fairly straight forward. Locating the TJ fuel filler bezel is critical. Too high and you are inside the tub above the wheel well..... Measure four times cut once.
post #8 of 29 Old 05-20-2013, 10:28 AM
superj
you cannot use copper pipe instead of stainless?
just wondering if there is a more common metal that would work also?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 29 Old 05-20-2013, 10:56 AM
jbolty
jbolty's Avatar
I used copper fittings to splice the different size hoses together.
jbolty is offline
post #10 of 29 Old 05-20-2013, 02:13 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I guess you could, but does the gas react with the copper tubing?? Heck, it is only a filler pipe so contact is limited isn't it!?
CRAP! I overspent on this project......
post #11 of 29 Old 05-20-2013, 02:48 PM
superj
Ha ha ha, I don't think it does. They use copper on all kinds of lines in different fields
superj is offline
post #12 of 29 Old 05-20-2013, 04:05 PM
idaholtby
Nice pics! I did the same to my rig many years ago and as you, I am getting old and forget the particulars, but reading this, it is exactly what I did when I did it for the very same reasons. Tried to find a way to go without the splice, but in the end, the splice was the only way. This is one of the best mods for a YJ, especially given the cost to complete.
idaholtby is offline
post #13 of 29 Old 05-20-2013, 04:07 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
And it is easier on the knees and back when fueling up!
post #14 of 29 Old 05-20-2013, 04:17 PM
idaholtby
No doubt!
post #15 of 29 Old 05-20-2013, 10:37 PM Thread Starter
Robob69
What are some rough Measurements I can use to not get into the Tub?
Robob69 is offline
