TJ flare swap on the YJ? - JeepForum.com
post #1 of 6 Old 09-07-2009, 06:12 AM Thread Starter
ROADDOG516
Ok im sure its on here somewhere but im short on time. Want to know if I get a pair of TJ flares at the Junk Yard, can I put them on my 93 with out any additional cutting or drilling?
YJ=THE LAST REAL JEEP!
1966 Willys
1993 YJ
2013 JKU Sahara
ROADDOG516 is offline
post #2 of 6 Old 09-07-2009, 06:28 AM
kingcn
I don't know about the junk yard, but you WILL have to cut and drill your fenders to put them on your YJ.
_____________________________________________
Front: Dana 30 4.10: Yukon Chrome-molly axles / Super Joints & Lock-Rite locker
Rear: Dana 35 4.10: Yukon Chrome-molly axles & Lock-Rite locker
C & C Fab Tube Fenders (giving these guys a plug because they treated me so well)
Home brew oil-pan/bell housing skid plate and gas tank skid plate.
kingcn is offline
post #3 of 6 Old 09-07-2009, 06:30 AM
dodger889
Simple answer NO you will have to drill new holes to mount atleast. If you are not opening up the wheel wells then why do this?
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 6 Old 09-07-2009, 08:36 AM Thread Starter
ROADDOG516
Thanks for the info just looking into it guess I dont need this mod not planing to run any larger than a 33x12.50, and Im not looking to trim the body, Ive got enough things to keep me busy without this as a project.
1966 Willys
1993 YJ
2013 JKU Sahara
post #5 of 6 Old 09-07-2009, 08:39 AM
Toms87
1987 YJ Wrangler
I run 33x12.5 and the flares (along with the cutting) gave me a good amount more room for flexing.
Toms87 is offline
post #6 of 6 Old 09-07-2009, 08:50 AM
93jeepyj
Do you just want them for a different look then ? theres really no point in going through the effort of putting them on if you arent going to make the wheel wells bigger at the same time. If you just want wider flares that bolt on there are plenty of aftermarket flares available that bolt right up to the yj without any cutting or drilling.
93jeepyj is offline
Sahara Flare Swap Possible? wenkebach TJ Wrangler Technical Forum 3 10-27-2006 12:41 PM
TJ Flare swap Jakesteads YJ Wrangler Technical Forum 4 07-17-2006 04:16 AM
flare swap SafetyMan YJ Wrangler Technical Forum 4 05-22-2006 06:23 PM
TJ Flare Swap clarifications TellyDSP YJ Wrangler Technical Forum 6 08-22-2005 08:51 PM
side marker lenses for TJ flare swap phlex234 YJ Wrangler Technical Forum 1 07-16-2004 04:20 PM
