#1 | |
tj flairs on my yj
Ok, I need a little wider flare since I installed my new 31/10.50/15s. I dont really want to spend almost $400 for aftermarket flares. I like the look of TJ flares over the stock YJ flares, and they are usually around $100 on ebay. I looked and done some searching and found alot, but nothing that answered my questions.
I know these wont match the pre existing holes, but are they a simple install? Do I have to cut or trim my body? My tires only rub a bit at full turn. I dont want to trim the body. will it look funny if I dont? Is there anything else that I have to do other than drill new mounting holes? I am also open to other alternatives or suggestions, but I do like the TJ flare look, however Im not sure that they will even be wide enough. I am not sure what my rim offset is, but they stick out quite a bit more than stock rims. Thanks to whoever gives me advice and doesnt lecture my lack of searching.
And I thought my other hobbies were expensive! http://www.mousebreaker.com/games/funkytruck/play.php 90 yj, new reman 4.2 ax15, weber 32/36, 2 1/2" RC lift, discos, 1" boom shackles, tcase drop (I HAD TOO). homemade flares. |
#2 |
For 31 x 10.5s....
You might want to look into a rim with the proper back spacing. You can probably find a used set for the same price as those flares and you don;t have to do the cutting, grinding and drilling needed to install TJ flares. |
#3 | |
#4 | |
#5 | |
Sorry maybe I should answer your question better. Yes, there is cutting involved in installing the flares. Yeah, you could install the flares without cutting but IMHO it would look funny. Yes... you will have to drill new holes. You will also have to figure something out with your turn signals that were on your fenders. Also if you have the factory side steps on your Jeep as I did on mine then the front flare will no longer link to it. |
#6 | ||||
I'm Old Gregg!
I'm in the process of doing this to my YJ now. I've done the rear but am waiting on turn signals to be shipped before I begin the front. I'll try to answer your questions...
This was the best site I found regarding the installation process: http://www.bc4x4.com/pv/yj/tjflares/ By the way, I found 2003 Rubicon flares and they are a little wider and taller then the standard TJ flares. If you can find some from a Rubicon, you will be pleased.
'88 YJ, getting newer one part at a time. Details on my profile, you should fill out your profile too. Early YJ Club, Member #1, Check out our group: Early YJ Club Quote:
#7 |
Not trying to hijack, but why do people get new flares when they get bigger tires? Is it illegal to have that wide of tires and not that wide of flares?
#8 | |
Originally Posted by mean90yj follow my logic on this one: the people who say that drive tj's, tj's have round headlights...boobs are round....people who drive tj's are boobs. |
#9 | |
#10 | |
This is not an exaggeration. My buddy was given a ticket for all 4 tires at $189/tire. He took it to court and the judge threw out 3 of them but still had to pay for 1 of them. SMALL TOWN AND BIG SHOT COPS IS WHAT IT AMOUNTS TO. Anyway even the judge said that it was ridiculus. You cant give him a ticket for every tire he said. but it still cost him $189.
#11 |
Eat, Sleep, Jeep
I did this a few weeks ago.. Like the look, but honestly it was a huge PIA.
Getting the old flares off was a pain, clamping, cutting, drilling etc was a pain.. Getting it all lined up was a pain.. Overall a full days job, like I said I like the way it turned out, but it was a bit of a tougher job than most posts would have you think. |
#12 |
i did my rears only in about hour an half came out mint and looks great, plenty of clearence for 33 x 12.5
91 yj 4.0 auto 35's, 3.5lift, booms, 410's aussie,armour,winch,booze, good times 89 yj 4.2 33x12.5,4 rc lift, etc (sold) 86 911 carrera too much stuff to list and alot closer to the ground |
#13 |
I have thought abou doing this as wel. HOwever i wuld only o he front. Sincei dont like how the front flars dont line up well.
2002 Jeep Wrangler TJ X; Smittybilt SRC front bumper, Warn M8000, 16x8 Rubicon Moabs on 31" Goodyear MTR's, 2.5" RC Proggressive lift, JKS Quick Disconnects, A to Z Rockers, Warn Steering Skid, 4WD rear bumper/tire carrier. Buy local seafood and support your local fisherman! |
#14 | |
Whoops.... i dont even have rear fender flares. But i still haven't been pulled over yet, so i guess tx doesn't have any laws about needing fenders. ![]() |
#15 |
For $149 (I think) you can get wider YJ flares from Quadratec. Front is just a wide YJ flare (use stock side marker) and rear is TJ style.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
