TJ Fender Flares - JeepForum.com
post #1 of 16 Old 08-09-2013, 05:32 PM Thread Starter
LivinCountry
TJ Fender Flares
I just got some TJ flares to put on my YJ. Should I expect any problems? Tips are greatly appreciated.
I'm a poor man because of the things I love...
92 Wrangler
00 Cherokee
LivinCountry is offline
post #2 of 16 Old 08-09-2013, 05:41 PM
jokerchief462
Haven't had any problems and no more tire rub
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 16 Old 08-09-2013, 07:32 PM Thread Starter
LivinCountry
Is the installation pretty seamless?
I mean could I use the YJ hardware to mount them?
92 Wrangler
00 Cherokee
post #4 of 16 Old 08-09-2013, 08:51 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
No. There have been countless folks here who have done this and provided write-ups.
Do a search and I'm sure you'll find them.
If you still have questions, just ask.
-John-
johnboy68 is offline
post #5 of 16 Old 08-09-2013, 08:52 PM
jokerchief462
Actually I did not reuse the YJ hardware on the rears. Mine had two location studs in the flares so I had to locate and drill. Then because I kept the trimming minimal I had to cut the lip off the flares. Once they were flat up against the tub I just used nuts and bolts with fender washers to install. The fender washers are bigger than normal so they will hold the flare better.
Have not installed the fronts yet.
post #6 of 16 Old 08-09-2013, 09:03 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
For maximum clearance, you'll be cutting about this much of the tub.
Luck Favours The Prepared
Anticanman is offline
post #7 of 16 Old 08-11-2013, 03:55 PM Thread Starter
LivinCountry
What did you use to cut your flarea, and did you do the front too?
92 Wrangler
00 Cherokee
post #8 of 16 Old 08-11-2013, 04:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I used a 3" pneumatic cutoff wheel to do the trimming. I opted for some metalcloak fenders up front.
post #9 of 16 Old 08-11-2013, 10:46 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Dude! You just made a new word: Flarea. Perfect!
YJOTM JULY 2014
DirtKar is offline
post #10 of 16 Old 08-11-2013, 11:14 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Shameless self promotion: http://www.jeepforum.com/forum/f12/t...heavy-1530015/
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luuca is offline
post #11 of 16 Old 08-12-2013, 10:03 AM
bgredjeep
1987 YJ Wrangler
I did TJ flares on my YJ many years ago. I left the fender edge on both flares and trimmed the front and rear fenders to fit. IIRC I used a jigsaw to cut mine out. The front flares were basically flush with the top of the fender so there was no overhang like Luuca saw.
I'm getting ready to install some TJ flares on my wife's YJ so I'll have to think about how I want to do these. It would certainly save some time in the front to trim the fender edge at least on the top section of the flare so I only need to trim the fender on the back section. I will make sure that any trimmed edges on the fender are covered by the edge on the flare. My updates will be posted in the wife's Jeep thread when I install the flares.
bgredjeep is offline
post #12 of 16 Old 08-12-2013, 11:00 AM
StanF
I have a set of TJ flares that I'm planning to install soon. I planning to leave the lip on the flares and cut the sheet metal to fit. A minor thing, but I don't want to see the edge of the sheetmetal.
I may only do the rear flares - I'm doing it for clearance and there's more of an issue in the rear.
StanF is offline
post #13 of 16 Old 08-12-2013, 11:16 AM
bgredjeep
1987 YJ Wrangler
Part of my reasoning is that my wife's YJ is black so the only place you would still possibly see any metal (at the top of the front flares) it would be the same color as the flare. We'll see which way I go when I get to that install.
post #14 of 16 Old 08-12-2013, 11:55 AM
Luuca
Luuca's Avatar
I'm not sure of any differences between the height of the front metal fenders from year to year, but I know that there was no way for me to physically have the top edge of the TJ flares flush with the lower flat edge of the fender where the edge rounds down while maintaining the lower front edge I the TJ flare flush with the lower front metal section of the fender.
Can you post a picture of your flush/flush TJ flares on your stock YJ front fenders?
Posted via my pretentious iPhone.
YJOTM never
Luuca is offline
post #15 of 16 Old 08-12-2013, 07:30 PM Thread Starter
LivinCountry
Yeah, fat-fingered on my stupid phone.
92 Wrangler
00 Cherokee
