tj engine and trans in a yj? - JeepForum.com
post #1 of 2 Old 01-24-2013, 08:48 AM Thread Starter
magyvermcb
Can you swap an engine and trans from a tj into a yj? I have a 93 with a 4.0 3 spd auto. I was given a 4.0 4 spd auto set up... Is it swappable?
3 spd is on the column.
4 spd is on the floor..
The engines are the same size.. So id assume the mounting for them is the same..
Would the 4 spd trans mount up to the existing transfercase? Or would i need a new transfercase?
I it might take some cosmetic work like removing the original shifter...
Chevy still runs deep but I wanted to understand again! O|||O
Matt
93 yj
magyvermcb is offline
post #2 of 2 Old 01-24-2013, 09:01 AM
Que89YJ
Look up AW4 swaps on the forum. It has been done numerous times from XJ and TJ. You need the harness and controller. A meter the schematics and a good sense of electrical wiring. Yes, you can do it. I would do some looking though. It seems like it mught be easier to keep the YJ electronics and adapt the AW4.
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
Que89YJ is offline
