TJ doors on a YJ? - JeepForum.com
post #1 of 20 Old 04-01-2013, 03:27 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
TJ doors on a YJ?
Came across a jeep on Craigslist and the guy has TJ doors on his YJ, is this possible with only a little work? His doors or body don't look butchered up or anything, looks clean. Would love to do this if its easy enough. Here's his link which has pics: http://annapolis.craigslist.org/cto/3687569853.html
'16 JK Sport
-2.5" TF Spring Lift
-315 BFG A/T
-3.73
BrandonYJReed is offline
post #2 of 20 Old 04-01-2013, 03:40 PM
tinktinkTJ
To my knowledge there are only 2 differences between the doors. 1st is where the striker is located on the tub. 2nd is the striker is a different shape. It shouldn't be difficult to swap in tj doors.
Edit: Here's a link to a tj to yj door swap. You can see the difference between the strikers. http://www.jeepforum.com/forum/f9/in...ors-tj-689693/
tinktinkTJ is offline
post #3 of 20 Old 04-01-2013, 03:41 PM
lancer27
yes this is possible. you would have to change the striker but i believe that is it. i have come across a thread with a lot of YJ's running TJ doors and tops. i would love to do this over this summer if cash allows.
97 tj i6 3.5 RE superflex lift. hp dana 30 4.56 gears ausie up front. dana 44 33spline alloy usa shafts arb rear. tom woods supper short sye and matching cv ds. 35x12.50x15 goodyear MTR's with kevlar. york OBA system. Metal Cloak High Arch tube fenders!(my favorit mod!!!)
lancer27 is offline
post #4 of 20 Old 04-01-2013, 04:27 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
The link I posted for the Craigslist jeep he has a normal stricter pin setup kind of like our YJ's not a u-shaped like the factory TJ one. Confused....
'16 JK Sport
-315 BFG A/T
-3.73
post #5 of 20 Old 04-01-2013, 06:40 PM
tinktinkTJ
I'm guessing the guy swapped the latch mechanism from the tj doors to a yj mechanism . I didn't even know you could do that . I would send the guy an email and ask how he made it work.
post #6 of 20 Old 04-01-2013, 06:57 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
Already did lol, waitin for a response still...
'16 JK Sport
-315 BFG A/T
-3.73
post #7 of 20 Old 04-01-2013, 07:03 PM
tinktinkTJ
If he gets back to you, can you post what he says? I would be very interested to know what he did.
post #8 of 20 Old 04-01-2013, 07:14 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
Not a problem.
'16 JK Sport
-315 BFG A/T
-3.73
post #9 of 20 Old 04-02-2013, 09:02 AM
flea1987
If the doors are that close could always just swap the door pannels if you just want the storage at the door base
flea1987 is offline
post #10 of 20 Old 04-02-2013, 09:04 AM
goducks3620
I thought the windshield rake is different enough that you can't swap TJ and YJ doors. YJ and CJ can be swapped though.
goducks3620 is offline
post #11 of 20 Old 04-02-2013, 09:13 AM
Carlos14
I believe the outside rake is different, but the TJ windshield is thicker which mean the inside rake has the possibility of being the same. The TJ windshield makes more of an inverted v shape whereas the YJ is a flat frame.
Luck Favours The Prepared
Carlos14 is offline
post #12 of 20 Old 04-02-2013, 10:17 AM
Siva283
I think this is what he did
Ask me how I know...
Siva283 is offline
post #13 of 20 Old 04-02-2013, 10:24 AM Thread Starter
BrandonYJReed
2016 JK Wrangler
No I don't think that'll work because the widow crank is in different spots. So the panels aren't swappable.
'16 JK Sport
-315 BFG A/T
-3.73
post #14 of 20 Old 04-02-2013, 10:36 AM
Siva283
I stand corrected. The only other thing that would make sense woulf be to switch the YJ lock set up into it. It ashame none of the pics show the side of the door where the catch mechanism is. Then we could easily figure it out.
Siva283 is offline
post #15 of 20 Old 04-02-2013, 10:40 AM Thread Starter
BrandonYJReed
2016 JK Wrangler
See the YJ has the window crank closer to the hinges.
'16 JK Sport
-315 BFG A/T
-3.73
