TJ D-35 parts in a YJ housing? - JeepForum.com
post #1 of 4 Old 10-23-2011, 05:14 PM Thread Starter
medic-11
Like the title says, do TJ dana 35 parts- like ring, pinion and carrier work in a YJ housing?
I kinda got screwed buying a set of 3.54 (turned out to be 3.07's) axles from "pariah24" on FloridaJeepers.net and since Ive now wasted my money to change up my gears, I need to find a cheaper way.
I cannot find a reasonably priced set of 3.54, 3.73 or 4.10 axles anywhere near me.
What I have found are two different "complete" 4.10 dana 30's, and a TJ 4.10 rear axle without spider gears, that could come in around my current budget.
My other option is to buy an 8.8 with 3.73's, and I found a carrier with 3.73 ring and pinion for the Dana30, also around the same money. I would need to add more money for the axle swap though.
I know the majority of you will say go 8.8, other than the gear ratio- but I would rather not swap to a Ford axle. Ive had my share of hot rods with 9" rears and I completely understand the strength issue, but my Jeep does way more highway miles than trail miles and only has 31's.
So can the carrier and ring/pinion from the 4.10 TJ axle be set up in the YJ 3.07 housing?
medic-11 is offline
post #2 of 4 Old 10-23-2011, 05:24 PM
jeepyj13
I dont see why not. same axle just 1 casing has perches for leaf springs and other for coil springs.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #3 of 4 Old 10-23-2011, 05:27 PM
tonylax48
I have a set of 3.55 with carriers and everything for the d30 and 35. i also i have 4.10s for a d35 with practically brand new bearings. I can hook you up with for cheap. Im not sure what you looking for. your post is a little confusing.
I would assume that the tj gears will fit to answer your question but im not 100% positive.
1990 YJ soon to be 4.7L, auto, d30 4.11 w/ spartan locker, ford 8.8 4.11 open, sye, 4in RC 2in BL
tonylax48 is offline
post #4 of 4 Old 10-23-2011, 07:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Buy the 8.8 and swap it! If you like the 3.73 gears, swap the Dana 30 to match too, if not then grab some 4.10 gears and outfit both axles. What is your desired tire size in the end? You're going to only want to regear once so make it count. Sell both Dana 35's and grab the other shafts out of the Dana 30 and sell it to recoup some of your costs in the 8.8.
And pariah24 is on this board too.
Luck Favours The Prepared
Anticanman is offline
Best online parts store for replacement parts NorCalCon TJ Wrangler Technical Forum 4 11-23-2010 04:19 PM
where can i get just the IPF h4 housing essie92 Wrangler General Discussion 5 11-16-2010 06:51 AM
D30 carrier bearing caps, safe to swap from housing to housing? 256ChiliPepper TJ Wrangler Technical Forum 9 11-07-2009 07:52 PM
ax-15 housing ersala89 YJ Wrangler Technical Forum 6 11-05-2009 09:41 PM
Milk-Carton parts? Admit it, you have lost parts! ZonaWrangler YJ Wrangler Technical Forum 4 04-18-2005 05:10 AM
