TJ Corner Guards - JeepForum.com
post #1 of 4 Old 08-28-2008, 09:37 PM Thread Starter
The Rat
TJ Corner Guards
I know some on here have the TJ corner guards on their YJ. Just wondering if any modification is needed to the tailgate hinges or anything like that to make them work. Looking at buying some to cover up some trail damage (and to prevent more) and also to give me a better idea on TJ flare fitment as well as motivation to relocate the gas fill.
OH WAIT. WHAT?
The Rat is offline
post #2 of 4 Old 08-28-2008, 10:13 PM
timatoe
timatoe's Avatar
I didn't have to modify the hinges or anything. The TJ hinges are much wider so the opening is well obviously wider. I used some spray on bedliner under mine because I didn't want sand and what not getting in there and grinding down the paint. I did the TJ flares at the same time to make sure they lined up well. Also the filler neck is in kind of a tough area right there due to the rear wheel well, but you can make it work.
timatoe is offline
post #3 of 4 Old 08-28-2008, 10:36 PM Thread Starter
The Rat
Thanks a bunch. I was almost positive it was you that had the TJ corners (I'm looking at buying similar ones) but I wasn't sure so I didn't just PM you.
Thanks again.
OH WAIT. WHAT?
The Rat is offline
post #4 of 4 Old 08-29-2008, 08:16 AM
sebastian22
I just ordered a set of the Gen-Right TJ corners.
http://www.genright.com/ProductInfo....ductid=CNR2001
Only thing i dont like is the gap on the tailgate hinges, since TJ hinges are bigger. I think I will get it filled in and go from there.
95 Black YJ
sebastian22 is offline
corner guards!? 03_X TJ Wrangler Technical Forum 15 04-16-2008 06:03 PM
Corner Guards... Wheels4186 TJ Wrangler Technical Forum 11 10-07-2006 08:18 AM
Corner Guards AZSahara TJ Wrangler Technical Forum 15 01-23-2006 09:30 AM
corner guards TJxcore TJ Wrangler Technical Forum 8 04-19-2005 05:29 PM
OYR corner guards white TJ TJ Wrangler Technical Forum 8 07-28-2002 08:50 AM
