TJ axle shafts in a 95 YJ..... 4WD dash light ???? - JeepForum.com
post #1 of 3 Old 04-08-2010, 11:52 AM Thread Starter
LSU-YJ
going to have TJ axle shafts put in my YJ to bypass disconnect feature for 4WD.... sounds like I will lose the 4WD light up on the dash since the switch is located and operated by the vacuum motor.
Is there a way to still have light on dash??? whats the trick guys?
Thanks
LSU-YJ
LSU-YJ is offline
post #2 of 3 Old 04-08-2010, 12:13 PM
Mark05059
take out the vac switch Original Replacement Parts 8134473 - 4WD Switch for 97-00 Jeep® Wrangler TJ with Model NP 231 Transfer Case - Quadratec
and wire this in its place.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 04-08-2010, 12:38 PM
bmgadg
Originally Posted by Mark05059 View Post
x2, works like a charm. You do need a weather pack connector to fit it, the one on the switch at the disconnect will not fit. I cut one off a 97 xj at the junk yard. You could probably find a new one online and wire it up.
bmgadg is offline
D35 axle: how different are driver and passenger axle shafts? ritjobbie YJ Wrangler Technical Forum 3 01-16-2009 06:47 PM
D35 Axle Shafts JBWood05TJ TJ Wrangler Technical Forum 7 11-14-2008 09:12 PM
Do the rear axle shafts easily pull out like the front shafts? jclark50 TJ Wrangler Technical Forum 2 04-13-2008 10:10 PM
D35 Axle shafts Turner-2000TJ TJ Wrangler Technical Forum 14 12-04-2006 12:18 AM
axle shafts jeep jake TJ Wrangler Technical Forum 10 01-17-2005 02:30 PM
