TJ axle shaft conversion? - JeepForum.com
post #1 of 17 Old 12-01-2003, 12:05 AM Thread Starter
Lavacrawler
Lavacrawler's Avatar
I was on another site and someone mentioned something about swapping the front YJ axle shafts with tj shafts.
What is the benefit & details of this swap and is there any write-ups on it?
Thanks
-Lavacrawler-
99 TJ
62 CJ5 Willys
88 Sami
89 Yamaha TW200
Lavacrawler is offline
post #2 of 17 Old 12-01-2003, 12:13 AM
YJWOLF
YJWOLF's Avatar
Benefits would be converting from the pre95 smaller 260 U-joints to post 95 297(dana 44 size) u-joints. And eliminating the vaccum disconnect. All you need to do is install 2 oil seals, and remove the fork from the vaccum disconnect, and use the rest of it as a block off plate. Also XJ shafts will have 297 u-joints also.
YJWOLF is offline
post #3 of 17 Old 12-01-2003, 12:16 AM Thread Starter
Lavacrawler
So by eliminating the vaccum disconnect is it going to be locked in all the time? Thus making the front driveline spin all the time?
99 TJ
62 CJ5 Willys
88 Sami
89 Yamaha TW200
post #4 of 17 Old 12-01-2003, 12:23 AM
YJWOLF
YJWOLF's Avatar
Yup, that is why TJ front Dshafts are balanced, and most YJ's are not. So just balance your Dshaft and you are good to go.
YJWOLF is offline
post #5 of 17 Old 12-02-2003, 12:11 AM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I could be wrong but I was under the impression that the 95 yj's have the x297 u-joints and the vacuum disconnect. Therfore thier front drive shaft does not spin all the time like the tj's
To view the NEW
click here!!!
tobias94yj is offline
post #6 of 17 Old 12-02-2003, 12:29 AM
YJWOLF
YJWOLF's Avatar
yup, most 95's have the 297 u-joints. Why i said post 95, as in including 95. Also 93-up XJ with ABS is a pretty sure bet for the 297 u-joints.
YJWOLF is offline
post #7 of 17 Old 12-02-2003, 12:32 AM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
How about a 94yj with abs? I have never looked to see what I have.
To view the NEW
click here!!!
post #8 of 17 Old 12-02-2003, 12:41 AM
YJWOLF
YJWOLF's Avatar
I dont think so, but you could measure and find out.
YJWOLF is offline
post #9 of 17 Old 12-02-2003, 10:12 AM Thread Starter
Lavacrawler
This may make me look stupid, but what are the two seals that you need.
99 TJ
62 CJ5 Willys
88 Sami
89 Yamaha TW200
post #10 of 17 Old 01-01-2004, 01:31 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
BTT ....
I need to know what seals to get as well. I mean, I know I need the seals that go on either side of the diff, but does anyone have a part number or anything? Will the seals that fit a tj/xj d30 work or do I need to look for a non standard part?
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #11 of 17 Old 01-01-2004, 09:05 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Well, I have been researching this all night.....
Apparently, Warn has a seal that will work but nobody knows the part number.
The other option is to use the standard non disco seal, but you have to "machine" the housing with a dremel or something to accpet it....
I also keep reading that DTD or Randys or Rustys sells a kit with a seal that will work, along with a cover plate for the vaccum .... but nobody seem to be able to verify this.
Anybody on here ever swapped in a once piece shaft for the 2 piece?
post #12 of 17 Old 01-01-2004, 09:11 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
I would take a look over at Pirate for the info. Ton of threads on it I'm sure.
Devious is offline
post #13 of 17 Old 01-01-2004, 09:32 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Actually, there is almost nothign over there about it that I could find ..... remember, pirate isn't very d30 friendly
post #14 of 17 Old 01-01-2004, 09:37 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Yes I forgot about that, how silly of me.
D60 or nothing at all!!!!11
Devious is offline
post #15 of 17 Old 01-02-2004, 12:09 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
More info for others thinkng about doing this....
The warn seal will not work, unless you have the warn alloy axleshaft. Apparently it is a different diameter.
Looks like I'll need to get 2 seals for a late model (matching the 1 piece shafts I have) and "machine" the pass side with a dremel 2-3mm to accept it. From there out it looks to be the same as changing the seal on the driver side....
Supposedly, The Jeep/Mopar part number for the late model (non disco) seal is: 4874477
I'll keep yall updated as I get this going over the weekend....
How-To: TJ Axle Shaft Conversion H3RTCH YJ Wrangler Technical Forum 117 Yesterday 02:37 PM
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 11:50 AM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 12:49 PM
XJ shaft conversion question czjeeper YJ Wrangler Technical Forum 11 12-20-2009 06:35 PM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 12:42 PM
