TJ axle conversion - JeepForum.com
post #1 of 12 Old 04-11-2013, 02:05 AM Thread Starter
Dake
Dake's Avatar
TJ axle conversion
Is it worth it? I got the axles. Now Im not sure I want to loose my 4x4 light or can I still get it to work?
Dake is offline
post #2 of 12 Old 04-11-2013, 04:33 AM
Jeepsr4me
You can still have the light, but it is not needed. As when the transfer case goes to 4x4 its in. Unlike with the stock system that had to wait till the sleeve was moved over the axle shaft for the front to work. Many ways to rig up a switch to turn that light on.
Jeepsr4me is offline
post #3 of 12 Old 04-11-2013, 06:19 AM
PA_YJ19
Yes u can still have a functioning light, I do. All u have to do is get the TC switch off of an xj or tj, they're like 15 bucs brand new. Take out the old vacuum motor and all vacuum lines that connect to it along with the switch on the TC. Then take the 2 wires that connect to the actuator on the axle and pull them back around/ over to ur TC where the old switch was. Pull the old switch out and connect those 2 wires to the new switch and spin ur new switch into the TC. For 15 bucs u can still have a functioning light, if u really wanna be cheap go take the switch off of one at a junkyard. All the switch is is a connector with a small ball on the bottom, when u shift the TC is punches the ball up sending a signal to turn the light on, everyone u put the TC in a gear u the linkage hits the ball and send a signal I activate the light. Pretty simple and only 2 wires.
PA_YJ19 is offline
post #4 of 12 Old 04-11-2013, 09:06 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Seriously?
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Luck Favours The Prepared
Anticanman is offline
post #5 of 12 Old 04-11-2013, 09:37 AM Thread Starter
Dake
Dake's Avatar
I just need the light the wife dont like the fact of not having it. But im going to get the TJ TC switch.
Dake is offline
post #6 of 12 Old 04-11-2013, 10:16 AM
jeepster93
jeepster93's Avatar
If you don't do anything but replace the axle shaft, the light will still work. The light is not a function of the axle shaft, but rather the vacuum switch.
Just leave the vacuum switch in tact.
You would just leave everything attached. That is what I have, 1 piece axle shaft and I just left everything else there, and I have the dash light and a 1 piece shaft and it was truly that easy.
jeepster93 is offline
post #7 of 12 Old 04-11-2013, 10:59 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I just needed a reason to not rip it out and add some other gauge in there.
post #8 of 12 Old 04-12-2013, 12:01 AM Thread Starter
Dake
Dake's Avatar
Mines just a light not taking up a spot in the gauge pod. I have the clock doing that. Now can someone tell me if this is the part I need? http://www.quadratec.com/products/52247_01.htm
Dake is offline
post #9 of 12 Old 04-12-2013, 12:10 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yeah the one I linked is good for a 91+
post #10 of 12 Old 04-12-2013, 12:23 AM Thread Starter
Dake
Dake's Avatar
Thanks or the help
Dake is offline
post #11 of 12 Old 04-12-2013, 01:53 PM
timatoe
timatoe's Avatar
That switch will work with all of them. If you look at the second post in the thread below there's a Dorman part number. You should be able to find that switch hanging in the "Help" section of any parts house for $12 or less. The pigtail part though they may need to order, but Napa carries a lot of those types of parts as well. As for wiring it all you are doing is switching a ground, so run one side to ground, the other to the wire coming off the current little blue vacuum switch on the firewall that goes to the light and bingo bango you're all set.
timatoe is offline
post #12 of 12 Old 04-12-2013, 09:51 PM
4.7stroker
You should be able to get that switch at Autozone for the same price.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
