TJ ax5/np231 conversion write-up - JeepForum.com
post #1 of 3 Old 02-17-2009, 04:18 PM Thread Starter
SteveJcoYJ
as part of my build i'm gonna be using the AX5/NP231/and driveshaft out of a 97' TJ in my 91' YJ. The motor is out of a 93'. On pre-94' YJ's you will need to convert to an external slave cylinder,
or you could convert the TJ trans to an internal slave, but thats a stupid idea.
to do this the way i did you will need your old YJ trans as a donor for parts
I scored the trans to the driveshaft for $200 of a guy on craigslist.
swap the mount brackets over
it's 4 bolts
an thats what your left with, next you'll need to put the mount from your YJ trans on it. Since im swapping an engine at the same time im doing all the bolting up on the ground and then just gonna shoe horn it all in
next, you will need to swap out the speedo gear housings, its a single blot that holds down a C-shaped clip, the clip fits into grooves on the housing, once you remove the single bolt the hole assembly can pull straight out. On the TJ there is electronic speedo gear, where the 91' had a cable. If you have an electronic speedometer cable then this step can be skipped.
removing from old ax5
SteveJcoYJ is offline
post #2 of 3 Old 02-17-2009, 04:19 PM Thread Starter
SteveJcoYJ
here is the electronic unit being removed from the TJ AX5, same exact process
an here is the old swapped in
since TJ's dont have half shafts in the front they just had a 4wd sensor in the place where the vaccum connector is for a YJ on the tcase, The thread an size is the same so you can swap the vaccum connector in its place
it just screws out, here is the connector on the TJ ax5
post #3 of 3 Old 02-17-2009, 04:19 PM Thread Starter
SteveJcoYJ
the CPS will also need to be swapped, different connectors, everything else is the same.
after that i swapped the lower shifter housing
its 4 bolts and then it picks right out
the same goes for the YJ trans
i cleaned the old housing out with brake cleaner and lightly sanded an cleaned all matting surfaces.
instead of hunting for the gasket
after its bolted back on your all set
next before re-installing the trans, there is never a better time to install a clutch kit
so i did, hopefully i'll be throwing it in the jeep within the week. i just need to buy a few missing bolts for my motor brackets.
NP231 Tera Low 4:1 conversion OR Atlas II sprowley YJ Wrangler Technical Forum 11 09-14-2009 06:46 PM
NP231 cable to electronic pickup(yj to tj conversion) need help! tuck TJ Wrangler Technical Forum 2 09-10-2009 06:21 AM
Will this fit a np231? (possible u bolt conversion) fireshadow YJ Wrangler Technical Forum 6 09-06-2009 02:27 PM
SOA conversion write up wessy YJ Wrangler Technical Forum 6 04-12-2007 04:17 PM
AX15/NP231 Conversion Diver Down YJ Wrangler Technical Forum 3 12-06-2004 01:49 PM
