Quantcast Tires Stick Out Too Much - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tires Stick Out Too Much
Old 04-30-2008, 02:22 PM   #1
dastro123
I bought a '89 Jeep Sahara for my wife recently. The previous owner had just installed a 4" Rubicon leaf spring lift kit. He also installed Cooper 33x12.50R15LT's mounted on Eagle Alloy 187's.
My wife loves the jeep but hates the tires because they stick out 6" beyond the flares and look too "monster truckish" in her eyes and completely soak you when the top is off and the street is barely wet. See pics:
http://flickr.com/photos/26153803@N07/2454596228/
http://flickr.com/photos/26153803@N07/2454677886/
The wheels are 15x10 and , have an offset of -46mm and backspace of 3 5/8". I'm new at this, but the wheels are spacing the tires too far away from the body, right?
I want to mount tires to the original matching Sahara rims that are 15x8 (pic). These rims backspace go the opposite direction of Eagles, allowing the tire to not stick out as much. I want the tires to be completely within the flares (looking somewhat stock), but have enough diameter to not make the jeep look dumb with the 4" lift. I'm thinking about 32x11.50's. We hardly do any offroading so the type of tire isn't too important. Am I right thinking the wheels are the problem? Any input is greatly appreciated!
'89 Sahara, 4" Rubicon lift, Cooper 33x12.50R15LT
dastro123 is offline   Reply With Quote
Old 04-30-2008, 02:34 PM   #2
jrollings
yea you need new wheels with more backspacing. stock wheels are i believe 5" or so
94 zj
Indiana National Guard
Member of the 638th ASB out of Lafayette, IN
91B All wheeled vehicle mechanic
88M Motor Transport Operator
jrollings is offline   Reply With Quote
Old 04-30-2008, 02:44 PM   #3
jeepbro's
those stock wheels are 5.5" back space and are only 15x7's, those tires on there currently could be put on them but they would rub when turning and probably rub the inner fender wells when going up or down, you could get some 33x10.5's on those rims, possibly 32x11.5's but you still might run into problems with them running, those are your chances at keeping the tires completely under the flares,
i personally would mount those tires you already have on the orig rims and get some 1 or 1.5" wheel spacers, to avoid rubbing and they would just barely stick out and also give it a nice rounded out look
2002 tj sahara 3" lift 35" km2, AtoZ rockers 10k lb winch, 4.56 gears, lock-rites front and rear
My jeeps
Carolina Offroad Forum
Coastal Carolina Offroad
East Coast Trail Raiders
jeepbro's is offline   Reply With Quote
Old 04-30-2008, 02:46 PM   #4
blue1989yj
Different wheels will change how far the tires stick out. I have 31x10.5 and they are still slightly past the flares. I am in the process of picking out a wider flare to replace the stock ones.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline   Reply With Quote
Old 04-30-2008, 02:47 PM   #5
lobukjeep
lobukjeep's Avatar
Yuo better get your measurment down to exactly what you want,so you don't spend your hard earned cabbage on the wrong thing..I had 31x10.5x15 on my 89 yj on stock rims and they rub the springs on tight turns.I have a set of outlaw1 rims now with the same tire and they only stick out about 3 inches at best.Not sure what the back spacing is on them though.Seems to be a happy medium.
"We don't call you son 'cause your bright"
lobukjeep is offline   Reply With Quote
Old 05-01-2008, 10:29 AM   #6
sprngrider
leave the tires alone and get wider flares
sprngrider is offline   Reply With Quote
Old 05-01-2008, 10:32 AM   #7
l3it3r
Agreed
l3it3r is offline   Reply With Quote
Old 05-01-2008, 10:54 AM   #8
SwearingYeti
Agreed again!
1991 Red YJ - 2.5L
1996 White XJ Sport - 4.0L
1979 Multi Colored CJ-5 - 360
1978 Harley Davidson Shovelhead
Stationed in Fairbanks, Alaska
Soon to be Kuwait
Then Undisclosed, Iraq.
SwearingYeti is offline   Reply With Quote
Old 05-01-2008, 11:36 AM   #9
YJGEEWA
I don't recomend spacers at all they are a DANGER to you and everyone else on the road, that's just my . Here is a stock wheel specs,Vendor: AMERICAN WHL (A78)
Part: 1365765
Style: A78 136 VENTURA POLISHED
Rear/Back Spacing: 3.75 INCHES
OffSet: -6MM,-.250 INCHES
Size Desc: 15 X 7
Lug Style: CONI SEAT/ACORN LUG
Hub Ring: Not Required
Center Cap: A78 1327000S
Even a fish wouldn't get into trouble if he kept his mouth shut.
YJGEEWA is offline   Reply With Quote
Old 05-01-2008, 12:00 PM   #10
LilViper95
Jeepaholic
LilViper95's Avatar
I would just buy some larger flares.....tell your wife she's lucky it doesnt look like this!!!! those bad boys stick out about 11 inches, I cant find flares that even come close to covering them!
04 Ram 2500 5.9L 24v HO Cummins
My Attempt at a Wrangler YJ Unlimited
Past builds:
Unwrecking a Rubicon
My Rusty Wrangler Project
LilViper95 is offline   Reply With Quote
Old 05-01-2008, 12:03 PM   #11
tcourdin
X3, there are some pics in my gallery of a couple of different brands of wider flares on my Jeep. I dont like getting soaked with water and mud while wheeling either.
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar.
tcourdin is offline   Reply With Quote
Old 05-01-2008, 12:07 PM   #12
flame0086
I'd buy the wife a rain jacket
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Old 05-01-2008, 12:30 PM   #13
jeepbro's
what i meant is adapters, that have lug studs mounted in billet aluminum that are same lug pattern,
not the actual spacers that just move wheels and relies on orig studs, i agree those are dangerous but adapters are just fine
My jeeps
Old 05-01-2008, 03:47 PM   #14
sprngrider
The aluminum spacers are great i have them installed in the front to prevent rubbing
Old 05-01-2008, 04:24 PM   #15
MLJeeper
MLJeeper's Avatar
i disagree on the spacer/adapter issue. I dont "like" them but they do their job safe enough. You HAVE to recheck the torque every now and then though.
As for the op, i agree with the ones that said get wider flares keep the tires.
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Glock Forum
