tires and gears - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > tires and gears
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 01-26-2002, 03:23 PM   #1
blackjeep
tires and gears
i am currently running 33's right now on my 95 4.0 and i am going to be installing a ford 8.8, it has the 4.10's. I will soon be going to 35's. now my question is am i going to be beatting myself by going with the 4.10's. Or should i go lower i dont want to if i dont have to. b/c then i would have to buy two sets of gears. 4.10's with 35 inch tires is better then 3.07's with 33 inch tires right.
i would appreciate any advice.
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline   Reply With Quote Quick reply to this message
Unread 01-26-2002, 03:45 PM   #2
SBall
Hi, I have a 92 with the 4.0L and 5 speed. I am running 35's with 4.10 gears. I would not want to go lower (4.56) unless I spent most of my time offroad-my jeep is my daily driver. On the interstate, I hit 70 mph at about 2300 rpms in 5th gear. I dont like going that fast, so typically I go 65 mph in 5th at about 2100 rpms. I also have a nice smooth take off and good acceleration. So basically, if this is your daily driver which sees the interstate some, Id definitely go with the 4.10's. If you are only going to be off-road or never above 50 mph, go 4.56 or 4.88.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline   Reply With Quote Quick reply to this message
Unread 01-26-2002, 06:25 PM   #3
rollinashortysahara
my roomate has a 92 yj spung over with 35's and 4.56 he rarely drive interstate because well first its plain scary without the steering correction kit and second he's at almost 3000 rpm going near 65-70 in 5th
rollinashortysahara is offline   Reply With Quote Quick reply to this message
