tires - JeepForum.com
post #1 of 9 Old 02-28-2002, 04:50 AM Thread Starter
collegewheeling
tires
i was just wondering if i could fit 31x11.50 with out a lift on a 94yj. I know it would be useless off road, however it will only not be lifted for a few weeks. cash flow permitting. And i can get a great deal on these tires now. Any suggestions?
collegewheeling is offline
post #2 of 9 Old 02-28-2002, 07:10 AM
dartboy
dartboy's Avatar
I'm no expert but from what I had read here, they will fit but you will get lots of fender flare rubbing. Probably damage the fender flares some. But if you are lifting it soon anyway, buy them. You can always put them on later or put them on now and avoid serious off roading.
Jason
90 YJ...Stock for now.
74 Dodge Dart Sport
dartboy is offline
post #3 of 9 Old 02-28-2002, 10:01 AM
bobznew
For the time being, they ought to work okay, as long as you don't plan on doing much flex. I would think they would rub with any flex at all.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #4 of 9 Old 02-28-2002, 10:11 AM
SBall
Yes, they will fit. In fact, I just saw a jeep with 31's on my walk over from my parking garage. He had no lift and had these tires on the stock 15x7 rims. Of course, he had almost no clearance. If you are careful and drive very slowly over bumps or potholes, you might not tear up your flares.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline
post #5 of 9 Old 02-28-2002, 12:56 PM
Don Tibbetts
Yes you can put those tires on without a lift. I had 30 x 9.50s on my stock 7" wheels with minimal rubbing. However, I had many friends who wanted that extra inch. They will fit but they will rub. You will rub your fender flares when you go over big bumps. If you're planning on lifting it soon and you've got a good deal on the tires now that won't be there when you get the lift, I would buy them and hold on to them until I got the lift or drive very carefully with them on.
Hope this helps
Don Tibbetts
Don Tibbetts is offline
post #6 of 9 Old 03-01-2002, 02:28 AM Thread Starter
collegewheeling
thanks for the info, i'm going to buy the tires and drive carefully till i get a lift
post #7 of 9 Old 03-01-2002, 11:32 AM
wetodddid
wetodddid's Avatar
I put 32x12.5 on my stock 89 before i did my lift this past weekend. they WILL rub. there is a semi-circular area where the tires have rubbed away some of the fender flare on mine. it looks fine but i am thinking of replacing them anyway. i ran like that since september...if that gives you any idea.
bling, bling.
wetodddid is offline
post #8 of 9 Old 03-01-2002, 06:13 PM
Billy Badass
They will fit but they will rub badly, here's my two cents. I have an 88' with a three inch body and 32x11.50's on the stock rim with out rubbing. Just go out and buy the 1 1/2" shackles, it will cost you about 60 to 80 bucks, but they will fit and you can still flaug it. That will take care of your problem and then you can sat that you have a lifted jeep.
Later
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
post #9 of 9 Old 03-01-2002, 09:06 PM Thread Starter
collegewheeling
yeah, i was thinking shackel, with a 1" body. but have to go slow, i'm on a college buget. thanks for all the advice, it's always good to get others opinions
Got my tires rotated. Now tires are excessively loud at highway speeds. televisionary Tires & Wheels 16 06-09-2010 09:45 AM
Help me with a logical solution for wheels/tires for my JK (want bigger tires) jcole JK Wrangler Technical Forum 8 01-27-2010 07:47 PM
TIRES PAST FENDER FLARES 15.5 in wide TIRES!!!! johnjr602 TJ Wrangler Technical Forum 57 10-14-2009 06:50 PM
What tires size tires are you running on a 3 inch lift afaletto YJ Wrangler Technical Forum 8 07-01-2009 02:04 PM
31" Tires and Stock Tires on New Wheels arcteryx23 TJ Wrangler Technical Forum 9 01-18-2006 10:26 PM
