Tires - JeepForum.com
post #1 of 3 Old 10-05-2013, 08:06 PM Thread Starter
Shooter878
Tires
With size tires can I put on a YJ or TJ without having to change rims, or lift it or modify the driveshafts, I think I had 31's on my old CJ7. And if I chose to do a 2.5 lift is that a body or suspension lift
Shooter878 is offline
post #2 of 3 Old 10-05-2013, 09:03 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Anticanman is offline
post #3 of 3 Old 10-05-2013, 09:09 PM
SeanB95YJ
no idea on the TJs, might be better to ask the same Q in the TJ forum
on stock rims (15x7) you can safely go as big as 31x10.5... but with no lift or any other mods (fender trimming) a 31 will rub.
without rubbing, you should be good with 235/75r15
most commercially made body lifts are even inch measurements... 1", 2" or 3". most will recommend not going bigger than 1" on a body lift
if you're thinking 2.5", that would most likely be a suspension lift
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
