Tired of getting the finger on the way to work?????? - Page 2 - JeepForum.com
post #16 of 21 Old 01-14-2010, 09:40 PM
dodger889
Disconnect the orange/black wire going to the radio. That is the only wire that is connected between the light circuit and the radio.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #17 of 21 Old 01-20-2010, 09:51 PM Thread Starter
jameskehler
New headlight switch $23. Having turn signals that work, priceless.
/l ,[___],
l--L-@lllllll@-
( ) ( )−Ω−)
jameskehler is offline
post #18 of 21 Old 03-12-2010, 08:55 AM
RollTideYJ
James,
So that was it, just a headlight switch caused those problems? I am having a similar issue, and don't even know where to start. Not sure if it is a ground issue, a short, or a switch. Without going into any detail, somehow, my brake lights, front marker lights, dash lights, and turn signals are all working in tandem. How are all these things connected? I hope it is just a switch.....
RollTideYJ is offline
post #19 of 21 Old 03-12-2010, 09:29 AM
airdevil85
check your grounds,,, I had a ground under the hood I forgot to hook up when I blew the horn the left turn signal and left head light would come one
1995 XJ - Totaled
1998 XJ - Totaled
1994 YJ - Sold
1998 zJ - Current
airdevil85 is offline
post #20 of 21 Old 03-12-2010, 09:51 AM
monkeyhouse
that is soooo funny man.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #21 of 21 Old 03-12-2010, 10:19 AM
93jeepyj
Check all the bulbs too I just went through a similar situation with my other car where one filiment was broken and touching the other in the bulb causing all kinds of wierd backfeeding problems for months. Abs light and airbag lights were popping on so I was thinking clockspring, cv shafts, unit bearings type stuff all over a 59 cent bulb.
93jeepyj is offline
Arm is tired In the open TJ Wrangler Technical Forum 16 05-15-2014 05:11 PM
aftermarket 3 or 5 finger clutch?? ghost183 YJ Wrangler Technical Forum 3 09-22-2009 03:35 PM
Tired of the air dam... BAMAJK JK Wrangler Technical Forum 35 02-28-2009 07:32 AM
What to do with a tired 4.2L? kingjrk YJ Wrangler Technical Forum 1 02-20-2003 03:26 PM
4.2 getting tired, what to do? bidnizman YJ Wrangler Technical Forum 8 04-05-2002 08:12 AM
