Tired of getting the finger on the way to work?????? - JeepForum.com
post #1 of 21 Old 01-06-2010, 11:01 PM Thread Starter
jameskehler
Ok I know that the wiring on Jeeps all depends on the PO. So here is my problem. When I apply the brakes with the parking lights off the radio comes on. Prior to this new problem I always had to turn on my parking lights to turn the radio on but just figured that the PO had used the ACC hot from the lights to power the radio no big deal. But not only is there a short some where but when I turn on my headlights my rear left turn signal does not blink it looks like it is on all the time. Also with lights off the left turn signal does not work at all blinks real fast but does not light up. When I use the turn signal all the tail lights dim but that is it. Took out the seat to get real comfortable under the dash and traced out all the wires under the dash with no short found and no change from original problem. My right turn signal seems to blink alot slower now. Tried changing the bulbs and checked to make sure ground to the body was good all checks out! Tired of getting the finger on the way to work every day and dont need a fixit ticket when i dont know what to fix.
/l ,[___],
l--L-@lllllll@-
( ) ( )−Ω−)
jameskehler is offline
post #2 of 21 Old 01-06-2010, 11:40 PM
Delta347
Did you try changing the blinker thingys in the fuse block?
Ive never known the head light and stereo circuits to cross but I know the stereo and in dash clock share a circuit.
Id take note of every power lead and follow it until u hit a power source, assuming u didn't do that. Check all your grounds, even your battery grounds where it connects to the body and block. Hows your voltage on the meter?
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #3 of 21 Old 01-07-2010, 01:37 AM
idaholtby
First off... disconnect the power for the radio (both 12v hot and accessory). It obviously is wired up wrong and you don't need it throwing a monkey wrench into the equation. When you say you checked the grounds, was that at the taillight housing mounting screws? What are the front turn signals doing at the same time when you describe what is happening with the tail lights? When you state that the turn signal "blinks real fast, but does not light up", do you mean that the turn indicator lamps in the dash flash, but the tail lamps do not?
idaholtby is offline
post #4 of 21 Old 01-07-2010, 07:32 AM
Que89YJ
X2 on the radio. You're probably back feeding the circuit through the radio and have a ground issue. Morning Idaholtby!
Que89YJ is offline
post #5 of 21 Old 01-07-2010, 08:26 AM
idaholtby
Morning Que! I just rotated back to day shift, haven't quite acclimated yet.
post #6 of 21 Old 01-07-2010, 09:03 AM
Que89YJ
I'm just back after a couple weeks off and I'm trying to get back into the swing of things too. Work is a pain sometimes, but the alternative is much much worse! LOL
Que89YJ is offline
post #7 of 21 Old 01-07-2010, 11:20 AM
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
I agree with the both of you, backfeeding a circuit. Yank the stereo out and re-install it correctly. I just finished a semester of auto electrical and spent alot of time messing with other peoples frustrations such as this.
idaholtby, are you in Meridian? I swear I've seen your rig around town. I'm guess from your profile your still out at the M plant. Things still moving there?
LB
_____________________________________
I own a Jeep, it's red and has big tires
lbsnowryder is offline
post #8 of 21 Old 01-07-2010, 01:33 PM
AO1
For some reason my YJ when you turn the key and start it the parking lights come on. When I have no key in it and turn the lights on the radio comes on too. I just quit looking for reasons. It had a stock radio in it when I bought it. I used a wiring kit to install the radio I think the wiring kit is crossed but I dont mind it, when I turn the ignition off and the radio is on that reminds me to turn the lights off. Let me know if you do find out what is wrong.
I.Y.A.O.Y.A.S.
AO1 is offline
post #9 of 21 Old 01-07-2010, 01:49 PM
idaholtby
Yep, I'm in Meridian. Things are fine in M's R&D, plenty of non-stop work.
post #10 of 21 Old 01-07-2010, 02:06 PM
lbsnowryder
I spent 10 years out there, I'm just using up that money for school now! I'm sure I'll see you around. Keep an eye out for me!
LB
post #11 of 21 Old 01-07-2010, 03:37 PM Thread Starter
jameskehler
Checked grounds at tail lights and replaced two different blinker relays. One on the fuse pannel and another that was under the dash. The front lights work as advertised. With lights off and I use the turn signal it makes the blinking sound real fast but does not light up anything not even the turn indicator on the dash.
/l ,[___],
l--L-@lllllll@-
( ) ( )−Ω−)
post #12 of 21 Old 01-07-2010, 06:00 PM
idaholtby
So go ahead and disconnect the stereo to make sure it isn't causing any issues. The fast cycling of the flasher with no lamp light up would indicate a short rather than a ground issue. Once the stereo is removed, and if the problem persists, then check power at the rear lamps when the turn signal is turned on. Type 1157 bulbs are being used, correct?
post #13 of 21 Old 01-07-2010, 08:36 PM
boyce1911
1977 FSJ Wagoneer
AO1 My jeep does exactly what yours does with the lights and stereo, but Ive got one more. When I try to dim the dash panel lights the running lights dim instead!
boyce1911 is offline
post #14 of 21 Old 01-11-2010, 02:57 PM
isuace
Maybe related. I had a weird thing going on where my radio would turn off when I used my turn signals. I figured that I had some sort of weird ground issue. I had to change the flasher relay when I installed some LED trailer lights, and the problem totally went away.
isuace is offline
post #15 of 21 Old 01-14-2010, 08:50 PM Thread Starter
jameskehler
Ok after much wire tracing again still nothing shorted. But when I was digging around I removed the headlight switch and opened it up. the contacts were pretty dirty so I cleaned them off and replaced it. The problem was solved for about a day. Now its back again. Going to Kraqgen tomorrow to buy new headlight switch to see if that solves it for good otherwise i will try somthing else. I really dont mind having to work on the little things except when I have no clue what is broken.
/l ,[___],
l--L-@lllllll@-
( ) ( )−Ω−)
Arm is tired In the open TJ Wrangler Technical Forum 16 05-15-2014 05:11 PM
aftermarket 3 or 5 finger clutch?? ghost183 YJ Wrangler Technical Forum 3 09-22-2009 03:35 PM
Tired of the air dam... BAMAJK JK Wrangler Technical Forum 35 02-28-2009 07:32 AM
What to do with a tired 4.2L? kingjrk YJ Wrangler Technical Forum 1 02-20-2003 03:26 PM
4.2 getting tired, what to do? bidnizman YJ Wrangler Technical Forum 8 04-05-2002 08:12 AM
