Tire size will it fit? - JeepForum.com
post #1 of 3 Old 08-10-2011, 08:55 PM Thread Starter
traumajunkey
Getting rid of F150. Thinking about swapping the truck tires unto my 1990 jeep. Tire size are 31 X 10.5 R 15. The jeep is not lifted. Will these work. They are brand new and I need a neww set for the jeep. Let me know. Thanks
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, totally worn out and proclaiming "WOW WHAT A RIDE!!!"
traumajunkey is offline
post #2 of 3 Old 08-10-2011, 09:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The tires will barely fit if you have some arch left in your springs. The best thing to do is transplant the tires and get a 1.25" body lift and they'll run just fine.
Luck Favours The Prepared
Anticanman is offline
post #3 of 3 Old 08-10-2011, 11:07 PM
stratostix
I currently have 31's on stock springs until i install a 4" lift. Granted i'm not driving it around as I'm currently partially rebuilding it but they fit. Altho i should mention that my rims are cragar soft 8's which have 4" of backspacing.
stratostix is offline
Just lifted. now figuring out tire size Tire size? usnavydoc TJ Wrangler Technical Forum 8 05-04-2011 09:58 AM
A couple of tire model and size questions (what size with stock gears) GraysonJeep JK Wrangler Technical Forum 17 07-22-2010 02:36 PM
Tire Size and Wheel Size Guess user77877 JK Wrangler Technical Forum 4 06-28-2009 11:22 AM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 08:20 AM
Spare Tire Size vs Tire Size Roadstar TJ Wrangler Technical Forum 2 02-20-2003 11:14 AM
