tire size - JeepForum.com
post #1 of 33 Old 02-11-2013, 03:58 PM Thread Starter
tattman
1987 YJ Wrangler
tire size
anyone know how big of lift and tires I can run on my 87 yj. I seen that rubicon express has a 4.5 and a 5 in lift for the yj could I get 37"s under it if I went that route I will also be puting flat fenders on it
tattman is offline
post #2 of 33 Old 02-11-2013, 04:07 PM
Steve707
Are you running stock axles and gears?
Steve707 is offline
post #3 of 33 Old 02-11-2013, 05:54 PM
BlueRubiconrich
it's not just what size tire can I fit, but what you have for gears that matters.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 33 Old 02-11-2013, 06:47 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Michaelgoesrawr is offline
post #5 of 33 Old 02-11-2013, 06:48 PM
jcmooreusmc
Should be able to fit w/ flat fenders and the 5" of lift. Probably need to do some trimming in the rear though. Like the others above said, I'd worry about the gears before throwing that much rubber under it.
jcmooreusmc is offline
post #6 of 33 Old 02-12-2013, 02:03 AM
lutzke21
Is your current set up stopping you from going places? Bigger tires equals more stress equals more crap broke. And a higher CG. Just something to consider.
Unless you've got a rare Canadian YJ, or it's already upgraded, the Dana 35 may not last wrapped in 37s, and that's assuming it's in good shape. Flat fenders and lift kits will be just the beginning. Fit is the easy part.
I have 35s with my RE 4.5 XD and flat fenders, but I have to do some trimming because I rub bad at full stuff. And that's with a 2" BL too.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #7 of 33 Old 02-12-2013, 10:35 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pass the please. Milk Duds anyone?
Luck Favours The Prepared
Anticanman is offline
post #8 of 33 Old 02-12-2013, 11:01 AM
Michaelgoesrawr
Are they swimming in butter?
post #9 of 33 Old 02-12-2013, 11:27 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sir I'm not supposed to put butter on the milk duds.
-you're supposed to wash your hands after using the bathroom, right?
Touché.
-to the top please!!
post #10 of 33 Old 02-12-2013, 11:37 AM
PastorBrian
1976 CJ5
the only limit is your wallet......and common sense. Axles, gears, drivetrain WILL be needed when you cross certain threshholds. You can "fit" about anything, but that is the least of your concerns.
PastorBrian is offline
post #11 of 33 Old 02-12-2013, 02:31 PM
Carlos14
I'll just leave this here...
Carlos14 is offline
post #12 of 33 Old 02-12-2013, 03:39 PM
b_a_mech
Leaning tower of Heep!
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #13 of 33 Old 02-12-2013, 05:38 PM
NHfireLJ
NHfireLJ's Avatar
Mind if I sit in? Have my own bag..
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #14 of 33 Old 02-12-2013, 05:41 PM
BlueRubiconrich
your profile says stock axles you should not run that big of a tire with your stock gears.
post #15 of 33 Old 02-12-2013, 08:19 PM
vdubbles24
What gears then, with stick axles on 37s?
I recently bought my yj. I'm assuming it has stock axles and gears. I run 55 at 1800 rpm in 4th. I'm new to jeep world so I am very curious.
Thanks
Brandon
vdubbles24 is offline
