Tire Size - JeepForum.com
post #1 of 7 Old 03-04-2011, 11:12 AM Thread Starter
Ulricn1
Tire Size
Ok... I have been quite stupid of late with my mod's, and I kept thinking bigger is better! so I went and got some 33" shoes for my baby; however...
while I have no problem with the clearance (sometimes it rubs a bits, when the springs are tight - i have a 2.5" lift) it goes pear-shape on the road...
At "high" speed, the steering wheel vibrates heavily and I can hardly reach 70mph (110 kph) on the road. Also, i think it weaken my performance in soft sand!
Have I made a mistake? Are YJ not advised with that kind of tire size?
thanks for the future help!
Ulricn1 is offline
post #2 of 7 Old 03-04-2011, 11:22 AM
scubamc
When you put on the lift you change your driveline angles. You may need to install a transfer case drop or install a slip yoke eliminator.
scubamc is offline
post #3 of 7 Old 03-04-2011, 11:26 AM
iDriveYJ
The tires might also be improperly balanced, I have 33x12.50s, have had them for years, your wheel bearing might also be worn out.
iDriveYJ is offline
post #4 of 7 Old 03-07-2011, 09:02 AM Thread Starter
Ulricn1
Tires Size VS. Re-gearing
After doing some research it seem that I may have to re-gear my axles, as I am running the std Dana 30/35 set-up.
If I do a re-gear, will I also need to upgrade my brake system? Also, if I re-gear a Dana 30/35, they are still quite weak (or so it seems), so wouldn't be better simply get a better axle?
If so, which axles could I use on a 92 YJ...
VERY confused...
Ulricn1 is offline
post #5 of 7 Old 03-07-2011, 09:25 AM
glenn-91YJ
glenn-91YJ's Avatar
VERY confused...
Well you're not alone. I have a 4" lift with 5/8" booms and 33s, I don't have any issues with vibrations as I currently have a TC drop and 4* shims on the rear leafs. With the 4.0 we have 3.07 gears which really need to be 4.10s with 33s. You have a few options. I went out and picked up a nice D30 out of a 4 cyl which has 4.10 gears for $100. The guy needed to get out of his garage. I'm going to go through it and replace seals and check bearings.
For the rear I picked up a Ford 8.8 out of a 2001 Explorer with 4.10 gears. There's some fabrication work to swap in the 8.8 but well worth it and there's plenty of documentation here and online. I just rebuilt a TC but didn't do an SYE because I'm waiting until I get the 8.8 in.
As far as brakes go...yea an upgrade is probably the smart thing to do. I'm in the process of swapping in a dual diaphragm booster/MC from an 06 TJ. I have a thread documenting the swap. I'm at the point were it's ready to go in, make a couple new lines and bleed the system. Hopefully I get it done before the weekend.
Here's the thread...
http://www.jeepforum.com/forum/f12/0...my-yj-1177891/
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #6 of 7 Old 03-07-2011, 10:14 AM
TheNewbie
Your gearing won't effect steering vibrations. I'd start with making sure your wheels are balanced properly, and make sure your steering alignment is OK.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #7 of 7 Old 03-07-2011, 10:30 AM
glenn-91YJ
glenn-91YJ's Avatar
X2 with TheNewbie...The steering wheel vibration is usually due to improperly balanced tires, bad wheel bearings, ball joints and tie rod/drag link ends. Did you have and vibration/shaking in the steering wheel before you put the 33" tires on?
-Thomas Jefferson
size , tires , YJ
A couple of tire model and size questions (what size with stock gears) GraysonJeep JK Wrangler Technical Forum 17 07-22-2010 02:36 PM
Tire Size and Wheel Size Guess user77877 JK Wrangler Technical Forum 4 06-28-2009 11:22 AM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 08:20 AM
Opinion about tire size vs. Lift kit size awol09 TJ Wrangler Technical Forum 25 09-29-2008 06:17 PM
Spare Tire Size vs Tire Size Roadstar TJ Wrangler Technical Forum 2 02-20-2003 11:14 AM
