tire fitting - JeepForum.com
post #1 of 7 Old 11-14-2013, 07:22 PM Thread Starter
89yjislanderr
tire fitting
i currently run 31x10.5xr15.
i was wondering if different width tires will fit the wheel. im wanting 32's, but i can only find then in 32x11.5xr15 and several other widths
89yjislanderr is offline
post #2 of 7 Old 11-14-2013, 08:03 PM
Reno72
Yes, 11.5's will fit, you may have some rubbing on the leaf springs at full turn, but that is easily fixed. I see you have a 3" lift so those tires will fit nice,
Reno72 is offline
post #3 of 7 Old 11-14-2013, 08:14 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Adjust these
Luck Favours The Prepared
Anticanman is offline
post #4 of 7 Old 11-14-2013, 08:21 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Adjust these
^ This. Here is a pic about 10 years old my Yj at The time had 32x11.50's on a 3.5" lift
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 7 Old 11-14-2013, 08:24 PM Thread Starter
89yjislanderr
thanks guys. would 33's put substantially more stress on the axles than 32's, or is it a negligible amount?
post #6 of 7 Old 11-14-2013, 08:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
33's put a substantially amount more stress than stock tires. The front axle can handle it. The rear axle can arguably handle it. The engine will struggle to cope with change.
post #7 of 7 Old 11-14-2013, 08:45 PM
Tom95YJ
Tom95YJ's Avatar
Nick is right , if you have an 89 you will have a non c clip d35 which has Flange mount shafts like a D44 and it is a little but stronger but either way for 33's you will need to regear 4:10's and 33's are about perfect for a 4.2l But for a 2.5l you'll. want 4.88
'99 XJ Black Betty
Tom95YJ is offline
