Tire Change Kit - JeepForum.com
post #1 of 8 Old 08-16-2011, 11:35 AM Thread Starter
purdueme06
Tire Change Kit
What do you guys have on board for a spare tire kit? I still have the original factory kit under the hood, but I've never used it and I like the idea of replacing it with a box.
What have you found to be a good bottle jack/lug wrench/box combo to fit neatly under the hood?
purdueme06 is offline
post #2 of 8 Old 08-16-2011, 11:40 AM
Reddy89
I keep a 1/2'' ratchet, extension, and some sockets in the console since the OEM kit doesn't fit my lugs. I might to try to fab something and put all of that (and more) under the hood.
Reddy89 is offline
post #3 of 8 Old 08-16-2011, 11:42 AM
92 Green YJ
92 Green YJ's Avatar
I don't keep a spare at the moment. I keep a good off road tire plug and patch kit I got from ORW. to get the wheel and tire off I keep a half inch impact gun and impact sockets for my lug nuts (I have on board air to run it) and my high lift with a ratchet strap for jacking. (i strap the axle to the frame to keep the suspension from flexing out so I don't have to jack it up as high to get the tire off the ground)
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #4 of 8 Old 08-16-2011, 11:48 AM
TheNewbie
The stock one...
Good idea about the strap though. I was wishing I had a wratchet strap last week when I inverted a shackle in Ouray. Do you know how hard it is to fully extend your springs and lift a wheel off the ground just by driving on a rock when you have no sway or trac bars and full length shocks?
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 8 Old 08-17-2011, 04:43 AM
NotThePainter
I've never enjoyed lifting with the high-lift for a tire change. Instead of strapping the axle to the frame I lift the tire to be changed with the hi-lift tire attachment, lower the tire onto a jack stand, remove the hi-lift, and then the tire. Reverse.
More work but it seems safer that way, especially on the trail. The jeep is supported by the jack stand under the axle tube.
NotThePainter is offline
post #6 of 8 Old 08-17-2011, 09:20 AM
92 Green YJ
My only issue with that is you can't always get a jack stand under it on the trail, and of course,you have to carry the jack stands now as well. Usually when I have to remove a tire it's to change a busted front axle shaft. Tire repairs are usually done with the tire inlace with a plug or two. The high lift really isn't bad as long as you do it right. I also welded some plate steel to the bottom of my high lift base to give it a bigger footprint and make it a bit more stable. But it worked just fine for me before I did that. In fact I've used the instability of the high lift to my advantage to get unstuck before. Jacked it up and drove off the jack
My
post #7 of 8 Old 08-17-2011, 12:29 PM
notmyj
2 Things....
1. Glad to see I'm not the only one who has done that
2. Thats the kind of unsafe, poor practices that get people hurt. Therefore we aren't allowed to talk about it.
Seriously, I have used my highlift the exact same ways as you describe, and no, I have never had a problem with it either.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #8 of 8 Old 08-17-2011, 12:41 PM
92 Green YJ
Originally Posted by notmyj View Post
2 Things....
i never said it was safe. but its effective. Obviously only to be done in a real bind when there is no other alternative and obviously make sure nobody is standing anywhere near it when you do it. Just throwing it out there as another use for a high lift.
My
tire change wranglerboy YJ Wrangler Technical Forum 18 02-14-2010 08:06 PM
how to change a tire? jdub2k5 TJ Wrangler Technical Forum 13 12-18-2009 09:24 PM
Gear Change without a Tire Change? TDmaster JK Wrangler Technical Forum 11 07-16-2009 04:51 PM
Tire change nammy Wrangler General Discussion 5 06-22-2008 06:43 PM
Change of alignment with tire size change? Achped TJ Wrangler Technical Forum 6 06-12-2006 11:25 AM
