Tire carrier/fold down tailgate write up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tire carrier/fold down tailgate write up
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-14-2012, 01:04 AM   #1
kawasaki4
Ok I have never seen this done the way I am going to do it so hey, why not share with the rest of you! My plan is to convert my current tailgate to a fold down CJ style, and then use the hinges the tailgate swung on as mounts for the tire carrier. This is going to be done as cheap as possible so I am sure that a lot of you will like that. Lets start with materials. My buddy bought a complete s10 blazer (93 or 94). Off of the blazer I pulled off the tire carrier itself and the limiting straps, free so far. The only write up I have seen with the s10 tire carrier utilized the blazer carrier to body mounts. I do not want to go that route because the mounts have a very odd shape that requires a LOT of cutting and I did not want to drill into my corner guards. I just realized TODAY that the blazer tire carrier will work with the current tailgate hinges so now it's just a matter of freeing them up an being able to use them, which is why I am doing the CJ style tailgate. This is what I have bought in parts so far for it, total cost was $38. Sheet of steel (to rivet to the body so the hinges are not attached to only thin metal), two powdercoated black door hinges( max load for two of them is 150lbs but I think with the weight being on the limiting straps it will be able to hold a lot more), largest pop rivets I could find.
I was hoping to be farther ahead with this tonight but I figured out I needed more supplies. I need another sheet of steel for the tailgate portion of the hinges, two 1/2x4in bolts, two 1inch O.D. washers, and two 1 inch O.D. lock washers. Ran into two snags while getting the tailgate off so be weary! First was getting one of the torx bits out where it bolts to the tailgate. Had to drill the shiet out of it!
Second pain in the arse was getting the pins out of the hinges. I didn't know how they were supposed to come out so I just took a grinder to the head of each pin and the bottom part where it mushroomed. The bottom one came out easy with a BFH and a punch but the top one I had to use a sawzall in the little space in the hinge that allows access to the pin.Here is a pic of the hinge with the pin ground down and of the rear of the heep with bare hinge mounts.
Here is one last picture of some bolts I had laying around holding it on the hinges, with top of the carrier above the top mount and the bottom of the carrier on the bottom of the mount it literally fits perfectly!
Right now the tailgate is off of the jeep and that is about it. I will be picking up the rest of the supplies needed tomorrow morning and hopefully be done tomorrow! Wish me luck everyone because I will need it
kawasaki4 is offline   Reply With Quote
Unread 06-14-2012, 01:17 AM   #2
Leans93
She's my density...
Leans93's Avatar
Good luck! I'm curious to see how it turns out
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline   Reply With Quote
Unread 06-14-2012, 01:53 AM   #3
kawasaki4
haha me as well good sir
Unread 06-14-2012, 01:54 AM   #4
AmmitOsiris
Sub'd
[color="navy"][B][U][URL="http://www.jeepforum.com/forum/f22/highschoolers-build-thread-springer-1352289/"]look at my plain lookin' build thread[/URL][/U][/B][/color]
[CENTER][B][U]JAKE "The Snake"[/U][/B][/CENTER]
[B][U]"SPRINGER" [COLOR="Navy"]1990 4.2L YJ[/COLOR],[COLOR="Navy"]BLUE[/COLOR],[COLOR="Gray"]GRAY hardtop[/COLOR], 2" O.M.E lift, P235/75/15 Pegasus Advanta A/T, with Black Steelies D windowed,[/U][/B]
[QUOTE=Anticanman;14153277][B]If you don't like it you can always take it through the car wash to erase it like an etch-a-sketch[/B][/QUOTE]
[QUOTE="Anticanman"][B]The grass is always greener on the other side of the fence. Especially when that grass is being use by coeds to play volleyball in bikini tops... :drool:[/B][/QUOTE]
AmmitOsiris is offline   Reply With Quote
Unread 06-14-2012, 09:52 AM   #5
kawasaki4
going to the store now to pick up the rest of the supplies!
Unread 06-14-2012, 10:36 AM   #6
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
well wadda you know! It would be nice if it fit inside the hinges.... begger cant be choosers I guess. Looks great either way! I might try it out myself!
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline   Reply With Quote
Unread 06-14-2012, 10:48 AM   #7
kawasaki4
I know I was just looking at the jeep and the carrier yesterday because I did NOT want to cut the other mounts down and make them fit on the body, and I was like wait a sec. The carrier slipped over the hinges perfectly!! who woulda thought! maybe this will become the new tire carrier to make!
Unread 06-14-2012, 11:14 AM   #8
deermjd
Looking good. What are your plans for latching the Blazer tire carrier to the tub?
94 ZJ Laredo (sold)
98 ZJ TSI (sold)
92 YJ 4.0
deermjd is offline   Reply With Quote
Unread 06-14-2012, 01:13 PM   #9
Luuca
Luuca's Avatar
I don't think that you are going to mount the tire carrier that way.. are you?
Would it make sense to mount the top bar into the top mount, and then, behind where your spare will cover the lower bar, make a bend and make a bend near the last bend point, to bring the bottom bar eye up into the stock mount? Aesthetically it would be much better, not to mention durability.
Visit my blog: A Daughter, A Dad, and a Jeep....Busted Knuckles.
Yellow Jeep Club Member #91
Then try posting in the street jeep section. They've got a whole bunch of useless garbage stuck on their jeeps.
Originally Posted by jbolty
This thread is not tech and is too much of a train wreck to move anywhere else.
Luuca is offline   Reply With Quote
Unread 06-14-2012, 01:49 PM   #10
kawasaki4
I'm not sure I will be able to bent it that much, it would be about 4 inches total but I am not against the idea. I'll see what I can do!
Unread 06-15-2012, 01:33 AM   #11
kawasaki4
So today I completed the fold down tailgate. The supplies I picked up today included four 1/2 bolts (will only use two but bought four in two different lengths in case I mount it different), nylocks and washers, 16 of the largest self tapping hex heads I could find, and a new drill bit because a lot of drilling will be done and I hate running to town for one thing. I bought another 22 dollar piece of steel because well I got paid today haha but for those on a super budget you can do what I was going to do and cut the one piece in four pieces and bolt each side of both hinges to one. Anyways I drilled what seemed like a hundred holes in everything! Here the tailgate is stripped down in all of its glory.
Here is the tailgate with a piece of steel mocked up to it. I had one taller piece and one shorter piece, this is the taller one but I ended up using it on the bottom of the jeep tub because it fit the space perfectly. I plan on getting a large piece for the tailgate at some point but remember.....BUDGET! (the other piece was already painted so I do not think the store would let me return it).
Here was the first problem of the day! I started my rivets to hold the steel to the tailgate and whaddya know, I did not even think about the tailgate shutting! Lucky this was the larger piece of the two and it needed to be cut down anyways because of the excess hanging off the sides and I realized I wanted it on the tub.
Here I just ground the heads off the rivets and punched them through. You can also see the excess steel that needed to be cut off.
Here is the smaller piece mocked up to the tailgate. This one will be easier to replace with another piece of steel if I go that route but who know.
This is why I used the larger of the two on the bottom portion. It make more sense to have this covered up opposed to the tailgate.
With tailgate latched in
Start of hinge install
With hinges on, looks super beefy. Hopefully it is secured enough
Close up of hinges. I like how they turned out.
With tailgate folded down! Limiting straps will come off of the blazer tomorrow and go onto this bad boy and I believe that will be the end of the tailgate stage. If I had all the right supplies and ran into no snags I could have done it in one day.
Now since that ordeal is done we can move onto the swing out carrier! This is the way I am going to mount it. The only thing I was worried about was not being able to open the soft top back window, but it does not hinder it at all. The picture below shows how it will mount, but will have grade 8 bolts, steel sleeves where the bolt is exposed, and lock washers and nylocks.
Fingers crossed but you should all be looking at a cheaply completed tire carrier with very minimal craftsman skills Feel free to make suggestions or constructive criticism!
Unread 06-15-2012, 07:55 AM   #12
skyj
Why not move your brackets to line up with the carrier?? mount them to your corner armor sandwiched with some bolts all the way through the tub. Then you solved your problem of it just being mounted to the thin tub sheetmetal. just my .02
build thread: http://www.jeepforum.com/forum/f12/skyj-eccentric-build-1467426/ '90 YJ 4.2 with 4.0 head, HEI. AX15, NP231 SYE, Dana 30 4.56 open/ 8.8 4.56 detriot locker. 1" shackles
skyj is offline   Reply With Quote
Unread 06-15-2012, 08:45 AM   #13
spyder98
I like your idea a lot and will be using your write up in the near future. 2?s will it be able to handle 35's? and would it be possible to cut the bottom bar and move it to make the ends fit on the hinges instead of the way u have them?
1995 Wrangler Sahara YJ. Rough Country 4" Series II lift 2'' BL, 1.5" Boomerang Shackles, 35x12.5R15 Dean Durango A/T, Cobra CB, Warrior Product Roof Rack
My build Post: http://www.jeepforum.com/forum/f12/marks-slow-build-thread-1358664/
spyder98 is offline   Reply With Quote
Unread 06-15-2012, 02:10 PM   #14
kawasaki4
I may go the route of moving the lower mount or I may leave it. The problem with moving the bottom mount is right now it has tons of strength because there is a support bracket on the inside of the tub, similiar to the support on the top one. I'm sure it will still be plenty strong if I move the lower mount and use some grade 8 bolts and some lock washers and nylocks, it's just a pain to get access to the back part of the mount.
Unread 06-15-2012, 03:33 PM   #15
Leans93
She's my density...
Leans93's Avatar
I say leave it where it is and throw some spacers where the tailgate used to connect. Then just throw some longer screws on and you'll be all set with little mod and cost as that seems to be the theme you wanted. Check out the below website. You can basically get any fastener in any size you could ever want.
http://www.mcmaster.com/#unthreaded-spacers/=hzqoyx
M.F. Leans
