Tire Carrier Build - JeepForum.com
post #1 of 17 Old 05-28-2012, 09:04 PM Thread Starter
linusb
Tire Carrier Build
I'm planning on building a swingout tire carrier onto my existing bumper. I've ordered my spindle kit (1 1/2 inch diameter) and am heading out to buy a 90 amp flux core welder from Harbor Freight tomorrow. I have no welding experience but have a friend who can lend a hand if I get stuck.
My existing bumper seems to have been fabricated out of two 2x2 square tubes stacked on top of each other. A few questions:
1) It seems like I should be able to drill the hole for the spindle and to weld it into place without removing bumper. Does this sound feasible? (looks like I'll have to drop my tank to remove bumper and I'd like to avoid that).
2) What drill bit should I get to drill my hole?
3) Does the spindle just get welded at the top or also at bottom? If it does get welded at the bottom, how do I do that? Do I drill two holes into bumper (top and bottom?)
4) I think my existing bumper is powder coated...do I need to strip that off or do I just weld right through it?
I'll put pictures up as I go.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #2 of 17 Old 05-28-2012, 09:18 PM
G30SFF250
Hold up now! What welder are you buying? Is it new or used? 90 amp is a lot so I am guessing 115 volt?
Flux core?!?!
This is the start of your build and many more to come. You should look into it if you haven't already.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #3 of 17 Old 05-28-2012, 09:21 PM
jbolty
jbolty's Avatar
That welder is almost certainly not capable of welding something like that, especially if you are not experienced.
What is the bumper made of? How thick? How is it attached to the frame? Pictures.
jbolty is offline
post #4 of 17 Old 05-28-2012, 09:28 PM Thread Starter
linusb
I'll get some pics up of the bumper tomorrow. So is a 240 volt welder needed for a project such as this? I don't have a 240 outlet in my garage.
The friend I mentioned has a 240 but I was hoping I could fab this mostly on my own.
linusb is offline
post #5 of 17 Old 05-28-2012, 09:31 PM Thread Starter
linusb
And it's attached to frame with 8 bolts. Pairs of two one above each other on outer ends and then also an inner set maybe 6 to 9 inches inward. Bolts protrude through rear of frame with nuts securing it.
linusb is offline
post #6 of 17 Old 05-28-2012, 09:54 PM
G30SFF250
Do you have a clothes dryer or something in the house that is 220 single phase? You can piggyback there.
I wouldn't recommend buying a welder that is underpowered.
Yes, a 220/240 volt welder is your best option. Will a 115 V stick, yes. Will it hold up, no.
post #7 of 17 Old 05-28-2012, 10:07 PM
timatoe
timatoe's Avatar
Do what you want but I think ultimately you'll be disappointed with that welder and the results of the bumper. I think you'll ultimately be a thousand times happier saving your pennies till you can get a 220 machine, be it a Lincoln, Miller, or Hobart.
timatoe is offline
post #8 of 17 Old 05-28-2012, 10:23 PM
G30SFF250
I agree!
A A/C 220 volt stick welder from Home Depot will do you better.
The only problem with stick welding is starting. Drag, get an arc, and go to it. Like anything, practice.
You will be happier with your build knowing you did it right.
post #9 of 17 Old 05-28-2012, 11:33 PM
skyj
Wo wo wo right there!!! Do not waist your money on harbor freight If you have never welded before it will end up looking like a pigeon pooped on your bumper. Your better off like others have said to save your pennys and get a good quality welder. I bought a Lincoln pro mig180 and couldn't be happier. One of the best investments I have bought for my jeep. I like to fab a lot of my own stuff. With that being said I started tonight my swing away tire carrier I built my spindle by buying a 3500# spindle from the trailer shop, I built it like besrk did. I aquired a smittybilt swing away from a unhappy smittybilt customer and am baseing my build off of that but with a stout spindle.
To answer your questions.
1) you probably won't be able to drill the hole without removing the bumper your tail light will be in the way.
2) you will want to use a bimetal hole saw and a real steady hand.
3) yes grind off any and all paint where you plan on welding or you won't be able to strike an arc.
4) yes drill a hole top and bottom, but If your bumper is indead two pieces of 2x2 welded together then you will need to drill 3 holes.
Hope that helps and good luck with the build.
Here is a shot of me
getting started on mine.
build thread:
skyj is offline
post #10 of 17 Old 05-29-2012, 09:17 AM Thread Starter
linusb
Thanks all for the great advice! I do have a 220 outlet in our laundry room that I can run a pigtail to...so I'm in the market for a used 220 volt welder. Found a few for sale locally...all stick welded I think and they look a bit older:
1) Hobart 250 with helmet-250 bucks
2) miller thunderbolt with cart - 235 bucks
3) older craftsman 100 bucks
4) 225 Lincoln with Cart - 200 bucks
Any recommendations?
linusb is offline
post #11 of 17 Old 05-29-2012, 11:58 AM
Leans93
She's my density...
Leans93's Avatar
I recommend a MIG welder for a beginner. I started with a Lincoln 180 from Home Depot. Still have that machine and it's awesome.
I also recommend removing the bumper as it will make the whole build go easier. As stated above I would also use a hole saw to cut the holes. I recommend welding both top and bottom of spindle. And yes remove paint from areas to be welded.
Here is a write up I did when I built mine. May give you some ideas if you read through it.
http://www.jeepforum.com/forum/f37/l...arrier-839569/
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #12 of 17 Old 05-29-2012, 01:37 PM
G30SFF250
AC/DC is a plus if this helps.
post #13 of 17 Old 05-29-2012, 08:10 PM Thread Starter
linusb
In reading up on welding, I'm having concerns about fire hazard. I don't have a dedicated shop for working...just an attached 2 car garage where my Jeep and wife's car get parked. Do you guys weld in an attached garage? My driveway is sloped and won't make a good welding area. I could use the back yard I suppose. Am I being overly worried?
linusb is offline
post #14 of 17 Old 05-29-2012, 08:49 PM
Leans93
She's my density...
Leans93's Avatar
I weld in my garage 90% of the time. I do have a fire extinguisher handy but I've never had to use it.
M.F. Leans
Leans93 is offline
post #15 of 17 Old 05-29-2012, 08:54 PM
superj
i weld everywhere, with a fire extinguisher. i have no dedicated place though. i have seen dedicated shops go up in flames because of carelessness though so if you are careful and think about what you are doing, your garage will be fine
I don't feel like working on anything at this time so i sold my yj.
superj is offline
My Tire Carrier Build NHfireLJ YJ Wrangler Technical Forum 12 02-07-2017 05:19 AM
Rear Tire Carrier Build Gregl8n TJ Wrangler Technical Forum 4 12-16-2011 07:50 PM
want to build my own spare tire carrier txlegman TJ Wrangler Technical Forum 4 03-09-2009 06:04 PM
build a tire carrier?? Possible?? Airborne4X4 TJ Wrangler Technical Forum 4 03-19-2006 03:30 PM
