tire carier - JeepForum.com
post #1 of 6 Old 10-21-2002, 06:05 AM Thread Starter
MugZy_YJ_94
ka-mai
MugZy_YJ_94's Avatar
2004 KJ Liberty
tire carier
i'm planning on making my oun tire carier. does anyone has done this? i would like to see some picuters of some different carriers to figure out how to make it. it will most likely be a triagle with reinforment in the middle, mounted on a bumber. i'm still stuck un the hings, the lock on the other side, and how to make the conecton with the frame. i would like to have the hings run in ballbearing, or if thats not possible in bushings. and the conection to the frame needs to be strong, because i want to put towhooks on it......
Now in the soccer mum class. Missing the YJ, but the KJ isn't bad...for now.
black jeepclub #35
MugZy_YJ_94 is offline
post #2 of 6 Old 10-21-2002, 11:24 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 6 Old 10-22-2002, 12:39 AM
thewoodscrew
http://www.rockstomper.com/catalog/pieces/hinge.htm
i plan on building a tire carrier with this spindle pretty soon. it's inexpensive and appears to be pretty strong.
87 YJ, 4.0 swap, Flowmaster, Pro Comp 4", JKS body lift w/ poly bushings, 33" Trxus M/T, Dana 30 w/ Aussie Locker and 4.10, 8.8 w/ 4.10 and a Trash-Lok, LoD rear bumper/ tire carrier
Thats not an oil leak, it's just marking its territory
White Jeep Club Member #8
thewoodscrew is offline
post #4 of 6 Old 10-22-2002, 08:44 AM
BuMpYJ
naekid, do your tires rub like no other? cause i think i have a set of those wheels in my garage with the stock tires on it
94 YJ not a trailer queen, breaks often
BuMpYJ is offline
post #5 of 6 Old 10-22-2002, 09:17 AM
KYgreenYJ
Look around at equipment shops and i bet you could find your hinges, like a trailer place or farm equipment place
Black 2012 JKUR 2.5" Rock Krawler Max Travel suspension with Bilstein 5100's, 35X12.5R15 MTRK's on MB Ultras, Sleeved and gusseted front axle with Synergy balljoints, JCR bumpers F/R
Old Jeep, SOLD:
94 Green YJ SE 4.0L 5spd
3.5" BDS lift, 1"MML/BL, Revolvers, SYE/CV, no track bars or sway bars, MORE sport cage
Green Jeep Club Member #20
KYgreenYJ is offline
post #6 of 6 Old 10-22-2002, 12:26 PM
NaeKid
NaeKid's Avatar
Naa .. those tires don't rub on anything anymore .. those are my baby little 33" that I put on 'er last summer. This summer she got a set of 38" tires .. and I have 35" for winter drivin' on the street .. some mud-terrain's that I am going to have siped.
Actually, I always had tire rub .. when I was running 235/75r15, I rubbed. When I put on the 33" tires .. I rubbed. I put the 38's on her .. and I rubbed. I installed Bushwacker flares .. I didn't rub anymore I think I have finally figured out my problem
Silver
NaeKid is offline
tj98 NV231 shifter linkage is falling out of its carier and 4hi 4lo not working. johnnyjeepster TJ Wrangler Technical Forum 3 10-04-2009 12:05 PM
carier Yule16MET YJ Wrangler Technical Forum 4 07-07-2006 07:10 AM
TJ pinion gear hitting ARB carier hansheb TJ Wrangler Technical Forum 5 01-23-2005 03:18 PM
Moving tire jack to spare tire bracket? Whts everyone think about this item on Ebay? brewc TJ Wrangler Technical Forum 2 11-19-2004 08:08 AM
Stock Spare Tire Carier smott TJ Wrangler Technical Forum 5 12-24-2003 10:37 PM
