Tips for the NOOB! - JeepForum.com
post #1 of 29 Old 12-31-2011, 09:13 AM Thread Starter
cfuruka
Tips for the NOOB!
Ok people, First time Jeep owner here. Just sold my 2007 BMW 650i convertible and got my brothers 1994 Jeep Wrangler YJ; So you can imagine what a pampered wuss I am! He used it strictly as a rock-crawler, but it's my only mode of transportation, so have to make it street worthy while still being able to play a little in the mud.
I've already took off the 33X13.5 bias-ply tires he had on it, and put on new 32X11.5 Radials. Not sure what I'm going to do with the Bias-Ply's yet, they are in excellent condition on black rims...
My tires stick out 7" past the side... so I just ordered 6" TAG Pocket-Style Fender Flares after reading on the forum here. Nobody had anything bad to say about them, unlike that Jeep Planet trash on eBay I almost got suckered into! Thank you JeepForum!
It has a 2" shackles on it with leaf-springs, and no sway-bars, front or back. She rolls like a boat on the high seas around corners, and constantly jumps off to the right when I hit bumps or shift at any speed... Got single RS 5000 shocks all around, but I don't know if they are any good due to them all being flattened out from axle roll while my brother was out climbing rocks. And lockers on it that make me worried that I've broken something when I corner hard, LOL!
I have a daughter who has to literally jump up to grab the roll-bar and pull herself up into the seat! So need a side-step. Was thinking of a Nerf-bar, but read on this forum that only Nerds and gay guys have Nerf-bars on their Jeeps...
So... I'm looking for any tips you all may have on what I should do with this thing. Parts you all recommend, stuff that I won't bend and break all up the next time I decided to floor it through my neighbors cornfield again but yet let me drive down the highway to work at 65mph without having to man-handle it the whole way.
cfuruka is offline
post #2 of 29 Old 12-31-2011, 09:32 AM
roadyrob
1987 YJ Wrangler
looks like you have been doing some reading allready but the best sugestion I can make for a noob is to read the stickys. also, you probably mean front and rear track bars as a yj only has a front sway bar, although your bro could have removed this too. if he did you might consider reinstalling, it should help with body roll. rock sliders make pretty good steps and are way cooler than nerf bars, grab handles on the roll bar will help your daughter get in, mastercraft makes really good ones but they are a little pricy. I have the smittybult ones, they are quite abit cheaper and work well. alot of guys have been geting good deals on shocks from skyjackers scratch and dent. hope this helps and welcome to the forum.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 29 Old 12-31-2011, 09:57 AM Thread Starter
cfuruka
Thanks! Yah, have a friend here at work who just told me that I HAVE to get Nitrogen Gas-Powered shocks... But first need to find out if the shocks I have are any good...
As for the "track" bars, thank you for the correction, they are missing. I believe that I have to buy new links? Because of the 2" shackles... Been told to look into quick-disconnects in case I ever want to take it back out on the rocks. Just need to figure out which brand to go with. Hopefully NOT the most expensive, lol!
cfuruka is offline
post #4 of 29 Old 12-31-2011, 10:00 AM
TSEJEEPERS
Is that a shackle reverse on the rear?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 29 Old 12-31-2011, 10:08 AM Thread Starter
cfuruka
Hmmmm... will have to ask. I've been told that if I tear the front shackle off and put in a reverse kit up front that it will help with the jerking to the side.
cfuruka is offline
post #6 of 29 Old 12-31-2011, 10:14 AM Thread Starter
cfuruka
Could have killed my brother! I got 94 miles on the first tank of gas I put in the thing, THEN he tells me that he's not maintenance her in 3 years! I did a full tune-up and got 170 miles off of this tank of gas. The damn center wire of the spark-plugs were burnt down into the ceramic!!
cfuruka is offline
post #7 of 29 Old 12-31-2011, 10:15 AM
oldtime_ironman
I an 100% sure that the shackles you have are causing the funky handling. I would lose them and get a proper spring lift kit such as the OME 2.5 inch kit with the heavy-duty springs. Both MORE and Curries make good shackles to go with this kit, especially their 5/8 boom shackles.
Far as side-steps go, many companies make rocker panel armor with bars built in. A to Z Fab and Metalcloak come to mind.
If the rest of it runs OK, then I would say that your best friend off-road would be a front locker.
oldtime_ironman is offline
post #8 of 29 Old 12-31-2011, 10:19 AM
RockWoRM
RockWoRM's Avatar
Welcome to YJ world.
We could use a little more info. on the Jeep.
First off, find out if it still has the stock axles and what kind/type of lockers. Does he still have the front axle vac. system in place?
Without knowing what springs are on it (lools like SUA from the pic) I would get some stock or near stock size greasable boom shackles. With only 33's, you should have clearance... but again, don't know what springs you've got. But that would be better than 2" over shackles.
Jumping to the side when you hit bumps could mean several things. Bad shackles 'could' be the culpret, but it could also be bad TREs, loose u-bolts, bad ball joints, bearings, ect. You'll need to do some homework/checking on that one.
Get new shocks to fit. I'm not a fan of the RS5000 anyway.
For body roll, you will deffinately need the sway bar! If your brother pulled it, along with the tracs, then see if you can get it back. Or check the classifieds for guys getting rid of theirs if he does'nt have it. IMO the tracs do little for the ride, so I would'nt worry about them, but the sway is essential to driving on road. Get a set of sway link disconnets and you're good to go.
As far as steps/rockers. That is up to you. There are a ton of good brands and styles to choose from. Keep in mind though, a rock slider step will only give you help at level with the tub. So if you want a lower step, you'll have to add one or go a different route. I made a home brew set using 2x6 tubing, and bolted them under the rocker pannel. This makes them a couple inches lower than sliders and offers a good step. I wheel purdy hard and rarely hit them, so the lower profile does'nt seem to be an issue as far as wheeling is concerned, so it is a matter of preference I suppose. Here's a pic so you can see what I've got.
hope that helps
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #9 of 29 Old 12-31-2011, 11:07 AM
YJames90
YJames90's Avatar
Tip number 1 is get the BMW back !!
Just kidding. Nice Jeep!
My 2.5 to 4.3 swap thread
YJames90 is offline
post #10 of 29 Old 12-31-2011, 12:21 PM
giggityjeeper
was thinking the same thing...
first and formost learn how to wrench and do your own work or this will short process... jeeps are money pits no ifs and or buts about it, dothe work yourself or it will add up to lots over time.....
REAL LYtho READ READ READ, before you do anything research... ASK.... everything you do to the jeep 10000% depends on 'WHAT' you going to do in the end with it...
if itsa DD and pavement princess, then no need for 6" lifts and 36" tires.... or anylift...
but ya... welcome to hell..... but it will be a fun kinda hell....
oh and I find it hard to beleive he did much of any rock crawling with that, unless it had some different tires and stuuf before you got it.... thiose tires would barely climb a wet driveway
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #11 of 29 Old 12-31-2011, 12:22 PM Thread Starter
cfuruka
Ok, the axels on it are stock.
Only rear locker on it. Lock Rite is the brand.
The shackles are custom, and springs are unknown, but not stock.
Will post some pics of it all here in a few...
cfuruka is offline
post #12 of 29 Old 12-31-2011, 12:32 PM Thread Starter
cfuruka
The tires alone on my BMW ran me $2000 a year! that is if I was lucky and didn't fine a nail... 6 speeding tickets last year alone kept my insurance at $350 a month... Problem is that it did 160mph and I just HAD to prove it every single day that I drove it! So... now with only $100 per month car insurance and NO $700 a month car payment, I hope the Jeep will be LESS of a money pit than my BMW
Especially since it will only go 70mph... downhill... with the wind behind me... 121,000 miles on a tired 4 cyl engine keeps me from making any trips now
cfuruka is offline
post #13 of 29 Old 12-31-2011, 12:40 PM Thread Starter
cfuruka
Just want to thank everybody for your help!
cfuruka is offline
post #14 of 29 Old 12-31-2011, 01:33 PM
giggityjeeper
Ever by a set of 36 TSL.... 2G is pfft for tires.... now add gears, lockers, lifts, etc to run said tires....
the payment will be less, if you 'use' it expect a few hun a month maintence
post #15 of 29 Old 12-31-2011, 05:53 PM Thread Starter
cfuruka
LOL! Well, like I said, this is going to be my main daily vehicle for awhile. So the 32's I have on it now are as big as I want to get. And I PRAY that I don't have to replace all those items every year!
One question I have is.... I think that I'm going to have to replace/rebuild the engine soon. I want to move up to the 6 cylinder instead of this 4 cylinder... Would it be cheaper to throw a 6 in my current Jeep, or should I just can this project and buy myself a Jeep that came stock with a 6 in it?
cfuruka is offline
a little help for a noob .. please.. BLuBeRii YJ Wrangler Technical Forum 16 12-31-2011 05:34 PM
Noob with noob questions. JonnyZero TJ Wrangler Technical Forum 17 12-28-2010 11:57 AM
Noob Help 96Dsmtunr TJ Wrangler Technical Forum 12 07-19-2008 06:14 PM
Buying tips for a newb/noob percent20 TJ Wrangler Technical Forum 6 09-06-2007 09:42 PM
Help out the NOOB!!!!! Trinitron12 YJ Wrangler Technical Forum 6 04-21-2007 07:06 PM
