Tips for changing brakes on '95 YJ.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tips for changing brakes on '95 YJ..
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 03-13-2008, 01:55 PM   #1
JEEPJUICE999
Hi, I'm about to change the brakes on my 1995 YJ 2.5L for the first time since I purchased it, the problem is I've never changed drum brakes before. I was wondering if there are any tools that go along with changing drum brakes(as i learned with disc and the tool for loosening the calibers). Also if anyone has any advice or information on reference guides for this, ty in advance
JEEPJUICE999 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 02:02 PM   #2
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Go slow, draw a pic of the parts and the springs.. Only do one wheel at a time.
That way when you mess up (we all do) you have another fully assembled wheel to compare it to.
Richmond88yj is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 02:14 PM   #3
Beachcruiser
1987 YJ Wrangler
The only hard part is re-tensioning the springs....a VERY large screwriver or prybar comes in handy. Wear protection, it's nasty stuff in there & it goes everywhere.
Loosen the bleed screw on the back of the plate FIRST & push the old shoes all the way in towards the center to make room for the new thicker shoes. Immediately retighten the bleeder & most of the time you don't have to mess w/ bleeding the system at all.
Wipe the drums' interior shiny surface clean & have them turned if they are really grooved (it's a couple bucks a drum).
Don't contaminate the new shoes w/ your greasy mitts....go wash them before you install the new shoes.
Go slow..you don't want a mistake here. The first one will take you 1 1/2 hours.....the second will take you 20 minutes. That's how we all learn!
probably out breaking stuff.
Beachcruiser is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 02:21 PM   #4
pat8942
These will make the job easier.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 02:33 PM   #5
Burnerman
Do your self a favor and buy the tools in Pat's pic. Brake spring pliers will save alot of swearing by themselves. They can be bought for about $10 @ the parts store. The retaining spring tool helps if you've never done it but I use a pair of pliers and have no trouble. The flare wrench is another must have for brake lines and bleeders. Don't cheap out here and get a good set or single. Check for proper size. Sears sells a set pretty cheap. HAve a Chilton or Haynes manual handy and be sure to get Shoes and the spring/ hardware kit. Use new springs and retainers. Clean the self adjusters good and use anti seize or hi temp brake grease on the threads and swivel ends. Don't throw the old shoes out! Most stores have a $5 core on them.
89' YJ Larado 4.0L,AX15
05' Grand Cherokee Limited, 2"OME lift and a Hemi.
Burnerman is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 02:35 PM   #6
BadAddetude
x2 on the Tools!!!!
Go to AutoZone/Advanced and see if they have a Drum brake servicing kit or whatever they call it. The 2 most important tools there are the reatining spring remover (screwdriver-type thing) and the "Spring pliers". Those 2 things make drum brakes SOOOOOO much easier. Screwdrivers just don't compare IMO.
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread: http://www.jeepforum.com/forum/f12/badaddetudes-build-project-hrp-602142/
BadAddetude is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 03:23 PM   #7
Bigboyky
If you don't have the tools and decide to try this, that's fine. When you get really p***ed walk away for about 30 minutes to an hour. These springs will drive you nuts. Walking away will help you in getting them on. And as stated the first side will take you forever, next side time will be cut in half or better.
Bigboyky is offline   Reply With Quote Quick reply to this message
Unread 03-13-2008, 03:58 PM   #8
zeus87gn
Automotive Neurosurgeon
zeus87gn's Avatar
1987 YJ Wrangler
A word to the wise....
If you have never done drum brakes before, the best thing to have around is knowledgable, experienced help (if you can find it). The actual brake tools in the picture are definetely a help, but if you don't know how to use them you can forget doing it in a timely manner.
Ask me how I know.
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
Holley Carb thread
zeus87gn is offline   Reply With Quote Quick reply to this message
Unread 06-27-2013, 04:34 AM   #9
bmedeiros678
What happened to pats pic?
bmedeiros678 is offline   Reply With Quote Quick reply to this message
