Tips anyone? - JeepForum.com
post #1 of 5 Old 12-26-2013, 08:33 AM Thread Starter
goinbroke89
Tips anyone?
As mentioned in a previous thread, I just installed a one inch body lift on my '94 YJ. I'm having trouble getting two of the bolts to thread back into the body. One on the passenger side rear and one near the rear shock on the driver's side. When I run the bolt up through the bushing and the spacer it won't start threading into the body. Suggestions please!
goinbroke89 is offline
post #2 of 5 Old 12-26-2013, 08:49 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
The captive nuts should move a little inside their cages. They could be rusted in place and hopefully not stripped.
I would shoot some PB Blaster up in them, then get a long screw driver and see if you can move them around a little. This could get them in the right place to pickup your bolt threads.
-John-
johnboy68 is offline
post #3 of 5 Old 12-26-2013, 09:15 AM
tom_sprecher
Make sure all of the installed bolts are loose. Look up into the bushing and make sure the hole in the body is centered on the bushing and threaded hole in the captive nut is centered in the hole. If not, push the body around and use a drift or Phillips to move the captured nut.
Tom
tom_sprecher is offline
post #4 of 5 Old 12-26-2013, 01:39 PM
bpounds
bpounds's Avatar
Also, take a good look at the lead-in on those two bolts. Maybe try them in a different hole. It's pretty common to see bolts that are fubar right out of the box, especially cheap imported stuff. Might need to run a die down them, or at least use a thread file.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #5 of 5 Old 12-26-2013, 04:44 PM Thread Starter
goinbroke89
I will give it another shot and post the results. Thanks.
