tips for 2.5 rebuild - JeepForum.com
post #1 of 4 Old 07-15-2009, 12:27 PM Thread Starter
gmorava
i have a 92 yj that has problems, i want to rebuild engine and was wondering if there is any machine work that i can have done to it to give it more power. something like shaving heads and how much to shave them, boring the bore and how much. and any other advice anyone has. i want to stay with the 2.5 so i dont have to do much other than pulling engine and rebuilding it and putting back in. any insight would be great.
gmorava is offline
post #2 of 4 Old 07-15-2009, 12:32 PM
4.7stroker
I would talk to your local mchine shop on compression ratios and cam choice for more power.
I would keep the CR under 10-1 to keep it mid grade gas friendly.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 4 Old 07-15-2009, 12:39 PM Thread Starter
gmorava
actually i was thinking of keeping it under 9.5:1 unless 10:1 works good, and was going to talk to machine shop also. just wanted to ask on here because i know "jeepers" have come up with some pretty cool stuff and have heard other "jeepers" talk about things that work well and know of any possible problems when things are modified.
gmorava is offline
post #4 of 4 Old 07-15-2009, 01:23 PM
ddrongowski
You could just buy an rebuilt engine. Quadratec has them for a little over $1k. It drop ships to your address, you swap out the engine, etc, then call the number on the invoice, and they come and pick up the old engine.
ddrongowski is offline
yo rebuild or not to rebuild that is thi question njdpb22 YJ Wrangler Technical Forum 22 12-01-2010 07:07 PM
Jeep Engine to Rebuild or Not to Rebuild booyia TJ Wrangler Technical Forum 31 10-02-2009 12:16 PM
SOA tips??? Misled1 YJ Wrangler Technical Forum 5 05-01-2009 02:42 PM
Engine rebuild tips hdfxrs91 YJ Wrangler Technical Forum 3 06-10-2007 03:30 PM
York rebuild tips (and I found the noise!) BNovak TJ Wrangler Technical Forum 2 11-04-2004 07:51 AM
